[AG-TECH] Help on Beaconviewer
Ravikiran Madduri
maddrav at charlie.cns.iit.edu
Wed Mar 14 14:50:39 CST 2001
Hi
Thank you very much for your quick reponse.I figure out the problem as i
was working on it for past 2 months.But i wrote a program that does the
work of archiving the multicast status over a period of time.I really
appreciate your help.But i have some more questions
1.How can i create my character in MUD
2.How should i subscribe to ag-tech mailing llist
Thank you in advance
Ravikiran
On Fri, 9 Mar 2001, Tony Rimovsky wrote:
> This appears to be related to a scaling problem that the DAST team is
> looking at.
> Right after the AG retreat, I was looking at this. I could set up an
> independant server with a few clients and it works fine. With the AG
> server, viewer client requests work for a few seconds after restart,
> and then nothing (IIRC, the server doesn't send any response to
> requests. It was either that, or the server sent back an empty
> packet, I'm not sure which off hand.)
> Getting this service runing again is important. It provides a path
> for archiving muliticast connectivity data over time. However, I
> haven't emphasised it with DAST because the memory problem they are
> trying to track down is more important overall.
> On Fri, Mar 09, 2001 at 12:34:21PM -0600, Ravikiran Madduri wrote:
> > Hi
> > My name is Ravi K Madduri.Iam working with Dr.Hood in IIT.We are planning
> > to have a AG node in IIT.But I have some problems running the beacon
> > Viewer program.Whenever i run the viewer in the following way:
> > java BeaconViewer -group 233.2.171.1 -port 56464 -server
> > beaconserver.accessgrid.org -serverport 9998 -interval 30 -verbose I get
> > the following error in GUI Server reply error and in the command window I
> > get ClientRecvSessionName error:
> > I would greatly appreciate if some one helps me out
> > Ravikiran
