[AG-TECH] Help on Beaconviewer
Tom Coffin
tcoffin at ncsa.uiuc.edu
Thu Mar 15 15:19:22 CST 2001
for the MOO checkout:
http://calder.ncsa.uiuc.edu/ACCESS/Demos/AccessGrid/moo_directions.html
At 02:50 PM 3/14/01 -0600, Ravikiran Madduri wrote:
>Hi
>Thank you very much for your quick reponse.I figure out the problem as i
>was working on it for past 2 months.But i wrote a program that does the
>work of archiving the multicast status over a period of time.I really
>appreciate your help.But i have some more questions
>1.How can i create my character in MUD
>2.How should i subscribe to ag-tech mailing llist
>Thank you in advance
>Ravikiran
>On Fri, 9 Mar 2001, Tony Rimovsky wrote:
>> This appears to be related to a scaling problem that the DAST team is
>> looking at.
>> Right after the AG retreat, I was looking at this. I could set up an
>> independant server with a few clients and it works fine. With the AG
>> server, viewer client requests work for a few seconds after restart,
>> and then nothing (IIRC, the server doesn't send any response to
>> requests. It was either that, or the server sent back an empty
>> packet, I'm not sure which off hand.)
>> Getting this service runing again is important. It provides a path
>> for archiving muliticast connectivity data over time. However, I
>> haven't emphasised it with DAST because the memory problem they are
>> trying to track down is more important overall.
>> On Fri, Mar 09, 2001 at 12:34:21PM -0600, Ravikiran Madduri wrote:
>> > Hi
>> > My name is Ravi K Madduri.Iam working with Dr.Hood in IIT.We are
planning
>> > to have a AG node in IIT.But I have some problems running the beacon
>> > Viewer program.Whenever i run the viewer in the following way:
>> > java BeaconViewer -group 233.2.171.1 -port 56464 -server
>> > beaconserver.accessgrid.org -serverport 9998 -interval 30 -verbose
I get
>> > the following error in GUI Server reply error and in the command
window I
>> > get ClientRecvSessionName error:
>> > I would greatly appreciate if some one helps me out
>> > Ravikiran
___________________________________________________________
Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
