[AG-TECH] Text search system for AG like Google.
Hiroyuki Komatsu
komatsu at taiyaki.org
Sun Feb 11 07:26:54 CST 2001
I have set up a full text retrieval search system for AG like
Google.
* For ag-tech ML
http://taiyaki.is.titech.ac.jp/~komatsu/ag/namazu.cgi
* For AG homepage (http://www-fp.mcs.anl.gov/fl/accessgrid/)
http://taiyaki.is.titech.ac.jp/~komatsu/ag2/namazu.cgi
This system is made by Namazu that is a full-test search engine.
(http://www.namazu.org/) It's very easy to install this.
Now I'm privately using it. But I hope that the AG homepage will
have publicly this system.
How to quick setting up is following:
1) Install Namazu into your system
Please read http://www.namazu.org/ ;-) and download a suitable binary
package or source code. If your system is Debian, just run
"apt-get install namazu".
2) Download html files of AG homepage
% cd <PATH-AG>
% wget -r -A html,htm,txt -l0 -np -N 'http://www-fp.mcs.anl.gov/fl/accessgrid/'
<PATH-AG> is a directory that can be accessed via HTTP.
After wget, <PATH-AG> will have a subdir 'www-fp.mcs.anl.gov'.
3) Write a config-file / Make indices of html file.
% cd <PATH-AG>
% cat > .namazurc
INDEX <PATH-AG>
REPLACE <PATH-AG> http://
^D
% mknmz
Wait a moment to make indices, it'll take one or two minutes.
4) Copy namazu.cgi to <PATH-AG>
% cp /usr/lib/cgi-bin/namazu.cgi <PATH-AG> (Debian environment)
When you correctly modify config files, this copy isn't necessary.
This action is merely for quick setup. :)
5) Enjoy catfish-fishing!
If you have some troubles to set up, please let me know and I will
help you.
Thank you.
Hiroyuki Komatsu
