[AG-TECH] Text search system for AG like Google.
Mark Hereld
hereld at mcs.anl.gov
Mon Feb 12 14:01:21 CST 2001
very nice. thanks for working that out. -- mark hereld
At 10:26 PM 2/11/2001 +0900, Hiroyuki Komatsu wrote:
>I have set up a full text retrieval search system for AG like
>Google.
>* For ag-tech ML
>http://taiyaki.is.titech.ac.jp/~komatsu/ag/namazu.cgi
>* For AG homepage (http://www-fp.mcs.anl.gov/fl/accessgrid/)
>http://taiyaki.is.titech.ac.jp/~komatsu/ag2/namazu.cgi
>This system is made by Namazu that is a full-test search engine.
>(http://www.namazu.org/) It's very easy to install this.
>Now I'm privately using it. But I hope that the AG homepage will
>have publicly this system.
>How to quick setting up is following:
>1) Install Namazu into your system
>Please read http://www.namazu.org/ ;-) and download a suitable binary
>package or source code. If your system is Debian, just run
>"apt-get install namazu".
>2) Download html files of AG homepage
>% cd <PATH-AG>
>% wget -r -A html,htm,txt -l0 -np -N
>'http://www-fp.mcs.anl.gov/fl/accessgrid/'
><PATH-AG> is a directory that can be accessed via HTTP.
>After wget, <PATH-AG> will have a subdir 'www-fp.mcs.anl.gov'.
>3) Write a config-file / Make indices of html file.
>% cd <PATH-AG>
>% cat > .namazurc
>INDEX <PATH-AG>
>REPLACE <PATH-AG> http://
>^D
>% mknmz
>Wait a moment to make indices, it'll take one or two minutes.
>4) Copy namazu.cgi to <PATH-AG>
>% cp /usr/lib/cgi-bin/namazu.cgi <PATH-AG> (Debian environment)
>When you correctly modify config files, this copy isn't necessary.
>This action is merely for quick setup. :)
>5) Enjoy catfish-fishing!
>If you have some troubles to set up, please let me know and I will
>help you.
>Thank you.
>Hiroyuki Komatsu
