[AG-TECH] Voyageur Recording
Ivan R. Judson
judson at mcs.anl.gov
Fri Dec 14 12:52:40 CST 2001
http://www.arachnoid.com/abouttime/
works very well for windows (2k, XP, et al).
This is a good solution for the display/control boxes that are out there.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Lisa Childers
> Sent: Friday, December 14, 2001 9:34 AM
> To: Don Morton; Sergeant A. G. Tech; Bill Nickless
> Subject: RE: [AG-TECH] Voyageur Recording
> Don,
> Thanks for the reminder about time-synching. Everyone in the community
> should be running an NTP client on their audio and video machines.
> Information on how to do this can be found at
> http://www-fp.mcs.anl.gov/voyager/AGTimeSynch.htm.
> The streams you see labeled "13 Flr Conference Rm" in the Finite Element
> Analysis recording have unique ssrc's, which according to the RTP protocol
> means they are independent video sources. Since voyager
> demultiplexes media
> data based on ssrc, they will appear in the stream list as
> multiple streams.
> One possibility for the many streams is that the vic responsible
> for sending
> "13 Flr Conference Rm" was relaunched several times during the recording.
> Each time vic restarts a new ssrc is assigned to the stream. However, a
> quick look at the "duration" fields for these streams does not match that
> scenario. I am wondering if this phenomenon might be caused by buggy
> multicast. Perhaps Bill Nickless can chime in on the possibilities here.
> The SCGlobal recordings from the showfloor voyager servers are
> being loaded
> onto another voyager server and will be available to the community next
> week. The ones you see on the voyager.mcs.anl.gov server are a small
> handful of the total SCGlobal set.
> Congrats on the success of your finite element seminar!
> Best,
> Lisa
> Behalf Of Don Morton
> Sent: Friday, December 14, 2001 7:29 AM
> To: Sergeant A. G. Tech
> Subject: [AG-TECH] Voyageur Recording
> I recall Mike Daw mentioning a problem on playback with
> Voyageur and I tried it for the first time (well, the first
> time by myself, without Lisa's supervision :). I too ran
> into problems but then noticed the "time offset" field
> (or something like that) in the stream menu, and one site
> was offset by over 5 seconds video and 43 seconds audio.
> by unclicking those streams from the stream menu, i was
> able to do a playback...... So, I know the importance
> of time syncronisation has been preached to us but, this
> is just a reminder to others who might try this that
> one of the first things you might want to do when trying
> to playback is "uncheque" the streams with large time
> offsets so they don't mess you up. BTW, I've notified
> the "guilty party" about the time sync problem :) :)
> Also (question for Lisa) - there were a BUNCH of streams
> that said something like "13 Conference Room........ H.261..."
> in the menu, then the "expected" streams from our actual
> event. Any idea where all those extras would have come
> from?" The specific event was from Windmer, 12 December,
> "Don Morton (Finite Element Analysis)".
> Finally, I tried looking for some of our sessions from SC Global
> but they seemed pretty incomplete and, in fact, I couldn't find
> any of the sessions I participated in. I can give specifics
> to Lisa privately but, am I correct in assuming that a number
> of the sessions didn't get recorded or preserved?
> Thanks,
> Don
> Don Morton http://MRoCCS.cs.umt.edu/~morton/
> Department of Computer Science The University of Montana
> Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
