[AG-TECH] New install -- planning for mics
David E. Bernholdt
bernhold at jumby.csm.ornl.gov
Fri Aug 10 17:03:03 CDT 2001
We're about to install an AG node and some Polycom H.323 equipment in
the same room. Looking at another room on site with the Polycom
equipment, I noticed that they were using only two microphones in a
large room, probably at least 20' x 30'.
They had the Polycom-supplied mic on the front wall, immediately below
the screen and a PZM mic on the ceiling just behind the projector.
The PZM was installed in a plexiglass shield, which keeps it from
picking up projector noise, and presumably helps funnel sound from the
rest of the room a little.
They say that get excellent results from this setup. In fact,
collaborators are apparently able to hear side conversations carried
out near the back of the room!
So I wonder as to the motivation behind using so many mics in AG (the
hardware spec says that every speaker should be within 2-5' of a mic),
and whether anyone has tried in AG a setup like I described?
Also, the spec says that all mics have to be plugged directly into the
Gentner. I can understand not mixing mics in different physical
locations into a single input because that could screw up the echo
cancellation algorithm. But does that mean I can't even put a simple
switch in the line, which would allow me to share a mic between the AG
and the Polycom? If this is a problem too, can someone please explain
why?
Thanks, David
David E. Bernholdt | Email: bernholdtde at ornl.gov
Oak Ridge National Laboratory | Phone: +1 (865) 574 3147
http://www.csm.ornl.gov/~bernhold/ | Fax: +1 (865) 574 0680
