[AG-TECH] Anybody available to help us doing multicast	  test and debugging?
    Xing Li
    xing at cernet.edu.cn
    Wed Aug  8 09:05:02 CDT 2001
dear yoshinori,
sorry for the slow response. i have just comae back from tibet.
i have removed the default.  i also noticed the multicast is not stable.
could you pls give us some advices?
best,
xing
Yoshinori Kitatsuji wrote:
> Xing,
> Mtrace shows a loop between APAN Tokyo XP and CERNET as follows. The
> default route is configured today in the CERNET router. Could you
> prior MBGP routes than multicast default?
> [ns2.jp.apan.net (203.181.248.30)]
> bash-2.05$ mtrace 210.25.130.1
> mtrace: WARNING: no multicast group specified, so no statistics printed
> Mtrace from 210.25.130.1 to 203.181.248.30 via group 0.0.0.0
> Querying full reverse path...
>   0  ns2.jp.apan.net (203.181.248.30)
>  -1  tpr2.jp.apan.net (203.181.248.13)  PIM  thresh^ 1
>  -2  tppr-atm1-0-0-11.jp.apan.net (203.181.248.237)  PIM/BGP4+  thresh^ 0
>  -3  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
>  -4  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
>  -5  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
>  -6  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
>  -7  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
>  -8  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
>  -9  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
> -10  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
> -11  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
> -12  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
> -13  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
> -14  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
> -15  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
> -16  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
> -17  cernet-tppr.jp.apan.net (203.181.248.113)  PIM/Static  thresh^ 0   [default]
> -18  tppr-atm1-0-0-11.jp.apan.net (203.181.248.114)  PIM/BGP4+  thresh^ 0
> Thanks,
> Y. Kitatsuji
> APAN Tokyo XP
