[AG-TECH] RedHat 7.1 & audio
    Matthew Wolf
    mwolf at cc.gatech.edu
    Fri Aug  3 15:48:46 CDT 2001
Depends on the box.  The dual Xeon has an SBLive (I know, I know).  The
others are using the recommended ensonique audiopci card (whatever the
model number is).  The appropriate things seem to come up under the
audio tab in rat, so at least *some* amount of information is getting
through from the driver layer.
Matt
Robert Olson wrote:
> Hm. Which audio cards?
> At 04:30 PM 8/3/2001 -0400, Matthew Wolf wrote:
> >I think that I have tried both the default RH7.1 (which seems to be from
> >the OSS-Free project, or whatever exactly it's called), and the
> >recommended for-pay OSS version.  I say I think because the OSS install
> >didn't look quite the way I expected, and I'm not convinced that I got
> >it right.
> >The default driver definitely works for local playback and recording.
> >Things are further confused because I have been trying this on several
> >different boxes, ranging from dual-processor Xeon to dual-processor PII,
> >and I'm not sure what (if anything) that effects.
> >Matt
> >Robert Olson wrote:
> > > Which audio drivers are you using?
> > > At 03:58 PM 8/3/2001 -0400, Matthew Wolf wrote:
> > > >I saw some comments about using 7.1 recently, and I wondered if anyone's
> > > >having success using it yet.  Specifically, I would like to know if
> > > >anyone's having luck with rat.  Vic is working beautifully -- I can see
> > > >real improvements in performance, probably because of the better SMP
> > > >behavior of 2.4.  But I can seem to get rat to work right.
> > > >The symptoms are that a) although it looks like I should be transmitting
> > > >or receiving stuff, I can't hear or do anything, and b) if I start up
> > > >sessions on two different machines, they see different network
> > > >statistics (loss rates, etc in the rat matrix view).
> > > >Any tips?  I tried compiling the newest version of rat, but it didn't
> > > >seem to help any, either.
> > > >Thanks,
> > > >         -- Matthew Wolf
> > > >         -- Research Scientist, IHPC Laboratory
> > > >         -- College of Computing, Georgia Tech
> > > >         -- mwolf at cc.gatech.edu
> >         -- Matthew Wolf
        -- Matthew Wolf
