[AG-TECH] Audio station problems.
Robert Olson
olson at mcs.anl.gov
Mon Apr 23 11:11:05 CDT 2001
When you go into a room, are there any error messages in the terminal in
which arm-eventlistener was started?
Does the arm show itself as being connected? Is there a heartbeat showing?
You are right, the quotes are key in starting rat from the command line.
Internally they are not needed because of the mechanism used within the arm
to start the process.
--bob
At 11:50 AM 4/23/2001 -0400, Chris Geddings wrote:
>Hello,
>I'm having a problem with my audio station. When I go into a venue,
>specifically the Test Room, rat doesn't seem to fire off on the
>audio station. I notice that the command line that arm-eventlistner
>attempts to fire off rat with is:
>/usr/local/ag/bin/rat -t 127 -C Test Room 233.2.171.39/42000
>When I use this syntax in a different window, rat complains about
>an invalid address.
>When I enclose the words "Test Room" in quotes, rat fires off no
>problem.
>This audio station was installed from the AG RedHat ISO.
>arm-eventlistener is from the ag-vrm-1.05-1.
>Thanks,
>Chris
