[AG-TECH] Audio station problems.
Chris Geddings
cegeddin at colltech.com
Mon Apr 23 12:06:52 CDT 2001
Uhmm...I don't know what I did, but it seems to be working now :(
Sorry to waste the bandwidth...
--Chris
Robert Olson wrote:
> When you go into a room, are there any error messages in the terminal in
> which arm-eventlistener was started?
> Does the arm show itself as being connected? Is there a heartbeat showing?
> You are right, the quotes are key in starting rat from the command line.
> Internally they are not needed because of the mechanism used within the arm
> to start the process.
> --bob
> At 11:50 AM 4/23/2001 -0400, Chris Geddings wrote:
> >Hello,
> >I'm having a problem with my audio station. When I go into a venue,
> >specifically the Test Room, rat doesn't seem to fire off on the
> >audio station. I notice that the command line that arm-eventlistner
> >attempts to fire off rat with is:
> >/usr/local/ag/bin/rat -t 127 -C Test Room 233.2.171.39/42000
> >When I use this syntax in a different window, rat complains about
> >an invalid address.
> >When I enclose the words "Test Room" in quotes, rat fires off no
> >problem.
> >This audio station was installed from the AG RedHat ISO.
> >arm-eventlistener is from the ag-vrm-1.05-1.
> >Thanks,
> >Chris
