[AG-TECH] Help on Beaconviewer, Subsetting Viewer Available
Ravikiran Madduri
maddrav at charlie.cns.iit.edu
Fri Apr 6 15:35:42 CDT 2001
On Fri, 6 Apr 2001, Robert Olson wrote:
> A concern I'd have with that approach is the requirement for CORBA on all
> the clients... is the orb something that is available in all the JVMs? Can
> you redistribute the jars for it? How does it handle the network link to
> the server coming and going?
The latest JDK has an builtin ORB inside it.But as far as i know the
clients do not require the ORB.They need to the reference of ORB that we
run at the server.Once they get the handle to the ORB it is a simple hack.
Regarding the network link i did not understand what you meant Would you
please elaborate on that
> On the topic of the beacon ...
> I've put a hack into the beacon server that writes a text-format dump of
> the server state once per minute. You can find this at
> http://www-unix.mcs.anl.gov/~beacon/table.out
> For the folks wanting to do archiving of beacon data, this should provide a
> means for getting the raw data. The format should be pretty
> self-explanatory; the tuples of data at the cross points are loss rate /
> delay / jitter/ out of order/ duplicates. The tuple is preceded with an "S"
> if the entry is stale (grey cell).
Actually I wrote some java programs that download the html page at
beaconserver.accessgrid.org:9999 page for every 5 minutes and then parse
the
HTML page and dump all the data into a mySQL database.Since the HTML Page
is always available I thought this database would go long way in archiving
the beacon data.Let me know what you think about this
> There is a php-based viewer available that allows the selection of a subset
> of the beacons to view, either by node name or by beacon name. This is at
> http://water.mcs.anl.gov/~olson/beacon.php
> This location will likely change at some point, but is up and working now.
We are at Illinois Institute of Technology and are currently in the
process aof acquiring resources to build a AGNode here.We need your expert
guidance in doing the same
> If you run an AG node and are not listed in the list of nodes, send me a
> note with your beacon name and I'll add you.
> This interface currently only shows the loss rates. Anyone who's interested
> in adding more support, let me know and I'll send you the php code to
> modify. (I've already spent more time puttering with this than I probably
> should :-)
> --bob
I can modify the php code to support all the features so please do send me
the code
Ravikiran
> >Iam presently working on a program that permanently fixes the scalability
> >problme in Beacon viewer.
> >Iam trying to use the distributed object paradigm for the beacons.Iam
> >currently using Visibroker's ORB to do that
> >We can run a event channel in which all the events of beacons will be
> >registered essentially i want to implement the Mediator pattern for the
> >beacons.So the beacons that register for these events can get the info of
> >other beacons.
> >Beaconviewer will just be another client which registers to all the events
> >that the beacons in the channel generate.
> >BeaconServer initialises the ORB and all the beacons get the instance of
> >the ORB thro the BeaconClient
> >The BeaconClients will also register to the EventChannel
> >Any ideas would be greatly appreciated
> >Ravikiran
> >On Fri, 9 Mar 2001, Robert Olson wrote:
> > > And the memory problem fix may also fix this ...
> > > At 04:24 PM 3/9/2001 -0600, Tony Rimovsky wrote:
> > > >However, I
> > > >haven't emphasised it with DAST because the memory problem they are
> > > >trying to track down is more important overall.
