[AG-TECH] Help on Beaconviewer, Subsetting Viewer Available
Robert Olson
olson at mcs.anl.gov
Fri Apr 6 15:04:00 CDT 2001
A concern I'd have with that approach is the requirement for CORBA on all
the clients... is the orb something that is available in all the JVMs? Can
you redistribute the jars for it? How does it handle the network link to
the server coming and going?
On the topic of the beacon ...
I've put a hack into the beacon server that writes a text-format dump of
the server state once per minute. You can find this at
http://www-unix.mcs.anl.gov/~beacon/table.out
For the folks wanting to do archiving of beacon data, this should provide a
means for getting the raw data. The format should be pretty
self-explanatory; the tuples of data at the cross points are loss rate /
delay / jitter/ out of order/ duplicates. The tuple is preceded with an "S"
if the entry is stale (grey cell).
There is a php-based viewer available that allows the selection of a subset
of the beacons to view, either by node name or by beacon name. This is at
http://water.mcs.anl.gov/~olson/beacon.php
This location will likely change at some point, but is up and working now.
If you run an AG node and are not listed in the list of nodes, send me a
note with your beacon name and I'll add you.
This interface currently only shows the loss rates. Anyone who's interested
in adding more support, let me know and I'll send you the php code to
modify. (I've already spent more time puttering with this than I probably
should :-)
--bob
>Iam presently working on a program that permanently fixes the scalability
>problme in Beacon viewer.
>Iam trying to use the distributed object paradigm for the beacons.Iam
>currently using Visibroker's ORB to do that
>We can run a event channel in which all the events of beacons will be
>registered essentially i want to implement the Mediator pattern for the
>beacons.So the beacons that register for these events can get the info of
>other beacons.
>Beaconviewer will just be another client which registers to all the events
>that the beacons in the channel generate.
>BeaconServer initialises the ORB and all the beacons get the instance of
>the ORB thro the BeaconClient
>The BeaconClients will also register to the EventChannel
>Any ideas would be greatly appreciated
>Ravikiran
>On Fri, 9 Mar 2001, Robert Olson wrote:
> > And the memory problem fix may also fix this ...
> > At 04:24 PM 3/9/2001 -0600, Tony Rimovsky wrote:
> > >However, I
> > >haven't emphasised it with DAST because the memory problem they are
> > >trying to track down is more important overall.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20010406/c36cb3e5/attachment.htm>
