[AG-TECH] Help on Beaconviewer
Ravikiran Madduri
maddrav at charlie.cns.iit.edu
Fri Apr 6 13:57:44 CDT 2001
Hi
Iam presently working on a program that permanently fixes the scalability
problme in Beacon viewer.
Iam trying to use the distributed object paradigm for the beacons.Iam
currently using Visibroker's ORB to do that
We can run a event channel in which all the events of beacons will be
registered essentially i want to implement the Mediator pattern for the
beacons.So the beacons that register for these events can get the info of
other beacons.
Beaconviewer will just be another client which registers to all the events
that the beacons in the channel generate.
BeaconServer initialises the ORB and all the beacons get the instance of
the ORB thro the BeaconClient
The BeaconClients will also register to the EventChannel
Any ideas would be greatly appreciated
Ravikiran
On Fri, 9 Mar 2001, Robert Olson wrote:
> And the memory problem fix may also fix this ...
> At 04:24 PM 3/9/2001 -0600, Tony Rimovsky wrote:
> >However, I
> >haven't emphasised it with DAST because the memory problem they are
> >trying to track down is more important overall.
