[AG-TECH] Fwd: Re: Possible bug in glibc-2.2.2-7.i386
Robert Olson
olson at mcs.anl.gov
Mon Apr 2 21:27:35 CDT 2001
This may be relevant to folks trying to use the AG software on RedHat 7.0 &
7.1 beta.
--bob
>Delivered-To: wolverine-list at listman.redhat.com
>From: Matt Wilson <msw at redhat.com>
>To: Philip Senechal <psenechal at kurant.com>
>Cc: RedHat Wolverine <wolverine-list at redhat.com>
>Subject: Re: Possible bug in glibc-2.2.2-7.i386
>User-Agent: Mutt/1.2.5i
>X-Loop: wolverine-list at redhat.com
>Sender: wolverine-list-admin at redhat.com
>X-BeenThere: wolverine-list at redhat.com
>X-Mailman-Version: 2.0.1
>List-Help: <mailto:wolverine-list-request at redhat.com?subject=help>
>List-Post: <mailto:wolverine-list at redhat.com>
>List-Subscribe: <https://listman.redhat.com/mailman/listinfo/wolverine-list>,
> <mailto:wolverine-list-request at redhat.com?subject=subscribe>
>List-Id: A discussion group concerning the Wolverine release
><wolverine-list.redhat.com>
>List-Unsubscribe:
> <mailto:wolverine-list-request at redhat.com?subject=unsubscribe>
>List-Archive: <https://listman.redhat.com/pipermail/wolverine-list/>
>Date: Mon, 2 Apr 2001 22:06:34 -0400
>A special addition to the 2.2.2 glibc in rawhide:
> o Some Java JVMs (both from Sun and IBM) don't work with the new
> floating stack feature of the i686 version of glibc. The
> failures are due to programming assumptions in the JVMs that are
> now invalid. JVM vendors are working on making the necessary
> corrections. Until corrected JVM packages are available, you
> may force glibc to use the deprecated stack model by setting the
> following environment variable:
> LD_ASSUME_KERNEL=2.2.5
>Cheers,
>Matt
>On Mon, Apr 02, 2001 at 03:37:34PM -0700, Philip Senechal wrote:
> > Please let me know if anyone else has encountered this problem or possibly
> > has a fix for it.
> > I installed Wolverine from the CD images with no problems. I ran up2date
> > and upgraded everything EXCEPT the glibc. ApacheJServ worked fine as long
> > as I did a "side-grade" to the i386 version of the glibc on the Wolverine
> > CD.
> > As soon as I upgraded the glibc to the current version on Rawhide
> > (glibc-2.2.2-7.i386.rpm), JServ will not start and I'm getting an ajp12
> > connect error on 127.0.0.1. I've tried this with IBM's JVM, Sun's JVM v1.3
> > and Sun's new BETA JVM v1.3.1. All work with the old glibc, but crap
> out on
> > the new one.
> > If anyone else is experiencing this problem, please let me know and I'll
> > report it as a bug. Or if you have found a way to circumvent the problem,
> > please let me know so I can fix my server :)
> > Philip
> > _______________________________________________
> > Wolverine-list mailing list
> > Wolverine-list at redhat.com
