nCruise 5/24: The Great SoundOff
Douglas Johnson
djohnson at osc.edu
Tue May 23 15:56:21 CDT 2000
The con call info for tomorrow is,
Telephone conference: 614-292-6666 Dial 1 to join a
conference. Conference number is 4338
On Tue, 23 May 2000, Lisa Childers wrote:
> Folks,
> Please join us this Wednesday in Lucky Labrador at 1:30 CDT for audio level
> drills. All chautauqua nodes should participate, as well as the nodes
> participating in Friday's DOE/Abilene meeting.
> Please come to the cruise with your gentner software ALREADY LOADED with the
> presets specified at http://www-unix.mcs.anl.gov/~insley/AG/preset.html.
> Doug will send conf call info before the cruise. Make sure your gentner has
> an analog line connected to it. You will need to dial your gentners into the
> conference call at the start of the cruise.
> We will spend the cruise adjusting audio levels in net-only mode, then in
> telco-only mode, and finally take turns being the net<->telco bridge node.
> It is particularly important that you pay attention to the mud during this
> cruise.
> Thanks,
> Lisa
Doug Johnson
Systems Developer/Engineer
The Ohio Supercomputer Center
djohnson at osc.edu
