Schedule for SC99 Access Grid w/ QoS demo
Karen Green
kareng at ncsa.uiuc.edu
Mon Nov 8 15:09:18 CST 1999
Rick:
OK. We will schedule the AG QoS demo at the times listed below. I will send
out an updated demo schdule as soon as I get confirmation about the change
in the Monday night schedule. Do you guys have any kind of abstract I could
get? I am putting together final press material and would like to make a
mention of this demo. The info needs to go to HPC Wire tomorrow.
Karen
At 02:43 PM 11/8/99 -0600, Rick Stevens wrote:
>Karen, this is great.. and I deeply appreciate the effort.. (I'm sorry for
>causing such
>a problem with things..).. Yes please pursue Monday evening if you can..
>--Rick
>At 02:39 PM 11/8/99 , Karen Green wrote:
>>Rick:
>>Here is what I can give you for sure:
>>2 p.m. and 5 p.m. on Tuesday
>>5 p.m. Wednesday
>>2 p.m. and 3 p.m. Thursday
>>I think I can get you on at 8 p.m. Monday night for the VIP show, but need
>>to check with some of the other people first.
>>With a little rearranging that's what's is available. Let me know if I
>>should persue the Monday night slot.
>>karen
>>At 02:18 PM 11/8/99 -0600, Rick Stevens wrote:
>> >Karen at this point can you just sign up the AG for QoS experiments
when you
>> >have a free slot on the displays.. about two session per day.. thanks.
>> >At 01:37 PM 11/8/99 , Karen Green wrote:
>> >>Rick:
>> >>The AG schedule may be open, but the Alliance booth demo schedule is very
>> >>tight. Even though there are not many demos using the Access Grid, we
have
>> >>a lot of people who are not doing Grid demos scheduled to use the AG
>> >>display system. That is why scheduling may be a problem for our booth. In
>> >>addition to the times mentioned below, we have 5 p.m. Tuesday and
Wednesday
>> >>available. An alternative mentioned by Ian was to use the workstation
>> >>dedicated to Globus for this demo. This would give us many more
scheduling
>> >>options, but I'm not sure if it would work in terms of using the AG from
>> >>that workstation.
>> >>Karen
>> >>At 12:44 PM 11/8/99 -0600, Rick Stevens wrote:
>> >> >I looked at the AG schedule and most of it is still empty.. Since
the AG
>> >> >group is
>> >> >still working out the schedule, it certainly is not closed yet. I
>> want to
>> >> >encourage
>> >> >everyone to check the AG Web site for the Virtual Venue schedule (which
>> >> >should start
>> >> >to appear later today).. with the new VV software multiple AG events
>>can be
>> >> >going
>> >> >on simultaneous (with different subsets of the sites participating),
and
>> >> >with with
>> >> >the ability to move from one virtual location to another.. This indeed
>> >>provides
>> >> >much more flexibility with the AG schedule..
>> >> >At 09:45 AM 11/8/99 , Karen Green wrote:
>> >> >>All:
>> >> >>Our demo schedule has been set for a month, so their is very little
>> >> >>available time on the Access Grid in our booth for this demo. Here is
>>what
>> >> >>is available:
>> >> >>Tuesday, 2 p.m.
>> >> >>Thursday, 3 pm.
>> >> >>*If our Monday night 8 p.m. demo can be moved, that slot might also be
>> >> >>available.
>> >> >>Please let me know asap if any of these times work. At this late
>> date, we
>> >> >>can't change the schedule too much because other people have already
>> >> >>committed their time and effort.
>> >> >>Karen
>> >> >>At 05:19 PM 11/5/99 -0600, Steve Tuecke wrote:
>> >> >> >I think all of the technical ducks are lined up for demos between
the
>> >> ANL,
>> >> >> >NCSA, and LBNL booths of Access Grid with network QoS using
>> >> >> >Globus/GARA. To summarize:
>> >> >> > * NCSA, ANL, and LBNL will each have AG nodes in their booths.
>>(Steve
>> >> >> >Lau confirmed the LBNL AG node today.)
>> >> >> > * There will be a completely separate network between these three
>> >>booths
>> >> >> >that will have the QoS support. Linda has confirmed that this is
>>all set
>> >> >> >for all three booths.
>> >> >> > The easiest way to handle this separate network is to setup
>> the AG
>> >> >> >machines to get their IP addresses from DHCP. Then when we want to
>> >> switch
>> >> >> >between normal and QoS network we swap network connections and
reboot.
>> >>Bob
>> >> >> >and Linda have worked out the details of this.
>> >> >> > * Because of current cisco router limitations, the QoS cannot be
>>done
>> >> >> >with multicast. So I believe the plan is to just to AG QoS demos
with
>> >>2 AG
>> >> >> >nodes at a time, using unicast UDP for audio and video. (Volker,
>>Linda,
>> >> >> >Bob: Can the demo be done with all 3 AG nodes simultaneously?)
>> >> >> >So the issue is now scheduling of the AG nodes for running with QoS.
>> >> >> >The infrastructure on which this demo is running is completely
>> disjoint
>> >> >> >from that used by other Globus demos, so the Globus group does not
>> have
>> >>any
>> >> >> >constraints on when the AG QoS demos can occur.
>> >> >> >I believe Terry Disz is coordinating the AG demos, so can the
NCSA and
>> >>LBNL
>> >> >> >AG schedulers please work with Terry to setup slots for
ANL<->NCSA and
>> >> >> >ANL<->LBNL demos. (Unless we think we can do all three
>> >> simultaneously, in
>> >> >> >which case we should do so.)
>> >> >> >The only input we have received on scheduling these demos is from
Rick
>> >> >> >Stevens, who wrote on that accessgrid mail list a few days ago, "we
>> >> should
>> >> >> >do this demo a number of times each day I would think."
>> >> >> >-Steve
>> >> >> >At 01:10 PM 11/5/99 , Rick Stevens wrote:
>> >> >> >>We need a schedule of when we want to do the QoS tests and get
>> that on
>> >>the
>> >> >> >>AG schedules
>> >> >> >>for the various booths.. Do we have a tentative schedule from the
>> >> Globus
>> >> >> >>group on
>> >> >> >>when they would like to do this.. ?
>> >> >> >>At 12:50 PM 11/5/99 , Patrick Dorn wrote:
>> >> >> >>>all,
>> >> >> >>>i believe that the technical issues are resolved. NCSA's cisco
>>7507 has
>> >> >> >>>been shipped, and the NCSA booth will have the requisite ATM
>> >> connection.
>> >> >> >>>linda and i will be setting up the PVC mesh, etc on site.
>> >> >> >>>i'm not sure that anyone has contacted the NCSA booth folks
>> regarding
>> >> >> >>>scheduling, though. whoever is in charge of this beast should
>> contact
>> >> >> >>>them soon. email to sc99 at ncsa.uiuc.edu will reach the committee.
>> >> >> >>>pld
>> >> >> >>>On Fri, Nov 05, 1999 at 12:06:48PM -0600, Charlie Catlett wrote:
>> >> >> >>> > Jeff/Tony/Patrick/John-
>> >> >> >>> > Are you in sync with Steve Tuecke & Co. regarding the
planned QoS
>> >> >>demo of
>> >> >> >>> > the AG at SC? Not sure who needs to be in the loop with the
>> >> cc'd ANL
>> >> >> >>> crowd
>> >> >> >>> > but please forward if I don't have all of the right NCSA
folks on
>> >>this
>> >> >> >>> > note. Among other things we need to make sure that the node in
>>the
>> >> >> NCSA
>> >> >> >>> > booth is available for the demo (not sure what the schedule
>> is for
>> >> >> this)
>> >> >> >>> > and that all of the technical ducks are lined up.
>> >> >> >>> > So can the right one of you please follow up with Steve?
>> >> >> >>> > Thanks!
>> >> >> >>> > CeC
>> >>>=====================================http://www.uiuc.edu/ph/www/dorn/==
>> >> >> >>>patrick dorn
>> >> >> >>>dorn at ncsa.uiuc.edu network engineer
>> >> >> >>>217.244.3319 ncsa network
>> development
>> >> >>Karen Green
>> >> >>Assistant Director for Communications
>> >> >>National Center for Supercomputing Applications
>> >> >>605 E. Springfield Ave.
>> >> >>Champaign, IL 61820
>> >> >>ph: 217-265-0748, fax: 217-244-7396
>> >> >>http://www.ncsa.uiuc.edu/
>> >>Karen Green
>> >>Champaign, IL 61820
>>Karen Green
>>Champaign, IL 61820
Karen Green
Champaign, IL 61820
