Multicast to NCSA
Robert Olson
olson at mcs.anl.gov
Mon Jul 12 10:26:40 CDT 1999
Here are mtraces to/from farmer.ncsa.uiuc.edu (the machine Tony Rimovsky is
running vic on):
Could it be the case that the latter form of mtraces aren't showing a
problem in the network, rather a problem in how mtrace works?
--bob
(dyfrig) % mtrace -t 127 141.142.21.149 dyfrig 224.2.177.155
Mtrace from 141.142.21.149 to 140.221.9.172 via group 224.2.177.155
Querying full reverse path...
0 dyfrig.mcs.anl.gov (140.221.9.172)
-1 destiny-11.mcs.anl.gov (140.221.11.253) PIM thresh^ 6 [default]
-2 bluto.ctd.anl.gov (130.202.128.1) Unknown protocol code 8 thresh^ 0
-3 cs-dng.anchor.anl.gov (192.5.170.130) Unknown protocol code 8
thresh^ 0 Reached RP/Core
-4 cs-atm0-0-11.ncsa.vbns.net (204.147.129.245) PIM/Static thresh^ 0
-5 charlie-atm0-5.ncsa.uiuc.edu (141.142.11.2) PIM thresh^ 8
-6 linus-atm0-15.ncsa.uiuc.edu (141.142.11.137) PIM thresh^ 0
-7 farmer.ncsa.uiuc.edu (141.142.21.149)
Round trip time 309 ms; total ttl of 10 required.
Waiting to accumulate statistics... Results after 9 seconds:
Source Response Dest Overall Packet Statistics For Traffic From
141.142.21.149 224.0.1.32 Packet 141.142.21.149 To 224.2.177.155
v __/ rtt 21 ms Rate Lost/Sent = Pct Rate
141.142.21.145
141.142.11.137 linus-atm0-15.ncsa.uiuc.edu
v ^ ttl 1 0 pps 0/3 = --% 0 pps
141.142.11.138
141.142.11.2 charlie-atm0-5.ncsa.uiuc.edu
v ^ ttl 10 1 pps 0/3 = --% 0 pps
141.142.11.1
204.147.129.245 cs-atm0-0-11.ncsa.vbns.net
v ^ ttl 10 0 pps 0/3 = --% 0 pps
204.147.129.246
192.5.170.130 cs-dng.anchor.anl.gov Reached RP/Core
v ^ ttl 10 86 pps 0/3 = --% 0 pps
192.5.170.129
130.202.128.1 bluto.ctd.anl.gov
v ^ ttl 10 698 pps 0/3 = --% 0 pps
130.202.128.5
140.221.11.253 destiny-11.mcs.anl.gov
v \__ ttl 12 97 pps ?/3 0 pps
140.221.9.172 140.221.9.172
Receiver Query Source
(dyfrig) % mtrace -t 127 dyfrig 141.142.21.149 224.2.177.155
Mtrace from 140.221.9.172 to 141.142.21.149 via group 224.2.177.155
Querying full reverse path... * switching to hop-by-hop:
0 farmer.ncsa.uiuc.edu (141.142.21.149)
-1 * * * Timed out receiving responses
Perhaps receiver 141.142.21.149 is not a member of group 224.2.177.155,
or no router local to it has a route for source 140.221.9.172,
or multicast at ttl 127 doesn't reach its last-hop router for that source
(dyfrig) %
