Multicast to NCSA
Linda Winkler
winkler at mcs.anl.gov
Mon Jul 12 08:31:03 CDT 1999
Unfortunately, mtrace on ciscos is broken. known problem for a while.
no fix in site.
lw
At 08:26 AM 7/12/99 -0700, Robert Olson wrote:
>Here are mtraces to/from farmer.ncsa.uiuc.edu (the machine Tony Rimovsky is
>running vic on):
>Could it be the case that the latter form of mtraces aren't showing a
>problem in the network, rather a problem in how mtrace works?
>--bob
>(dyfrig) % mtrace -t 127 141.142.21.149 dyfrig 224.2.177.155
>Mtrace from 141.142.21.149 to 140.221.9.172 via group 224.2.177.155
>Querying full reverse path...
> 0 dyfrig.mcs.anl.gov (140.221.9.172)
> -1 destiny-11.mcs.anl.gov (140.221.11.253) PIM thresh^ 6 [default]
> -2 bluto.ctd.anl.gov (130.202.128.1) Unknown protocol code 8 thresh^ 0
> -3 cs-dng.anchor.anl.gov (192.5.170.130) Unknown protocol code 8
>thresh^ 0 Reached RP/Core
> -4 cs-atm0-0-11.ncsa.vbns.net (204.147.129.245) PIM/Static thresh^ 0
> -5 charlie-atm0-5.ncsa.uiuc.edu (141.142.11.2) PIM thresh^ 8
> -6 linus-atm0-15.ncsa.uiuc.edu (141.142.11.137) PIM thresh^ 0
> -7 farmer.ncsa.uiuc.edu (141.142.21.149)
>Round trip time 309 ms; total ttl of 10 required.
>Waiting to accumulate statistics... Results after 9 seconds:
> Source Response Dest Overall Packet Statistics For Traffic
>From
>141.142.21.149 224.0.1.32 Packet 141.142.21.149 To 224.2.177.155
> v __/ rtt 21 ms Rate Lost/Sent = Pct Rate
>141.142.21.145
>141.142.11.137 linus-atm0-15.ncsa.uiuc.edu
> v ^ ttl 1 0 pps 0/3 = --% 0 pps
>141.142.11.138
>141.142.11.2 charlie-atm0-5.ncsa.uiuc.edu
> v ^ ttl 10 1 pps 0/3 = --% 0 pps
>141.142.11.1
>204.147.129.245 cs-atm0-0-11.ncsa.vbns.net
> v ^ ttl 10 0 pps 0/3 = --% 0 pps
>204.147.129.246
>192.5.170.130 cs-dng.anchor.anl.gov Reached RP/Core
> v ^ ttl 10 86 pps 0/3 = --% 0 pps
>192.5.170.129
>130.202.128.1 bluto.ctd.anl.gov
> v ^ ttl 10 698 pps 0/3 = --% 0 pps
>130.202.128.5
>140.221.11.253 destiny-11.mcs.anl.gov
> v \__ ttl 12 97 pps ?/3 0 pps
>140.221.9.172 140.221.9.172
> Receiver Query Source
>(dyfrig) % mtrace -t 127 dyfrig 141.142.21.149 224.2.177.155
>Mtrace from 140.221.9.172 to 141.142.21.149 via group 224.2.177.155
>Querying full reverse path... * switching to hop-by-hop:
> 0 farmer.ncsa.uiuc.edu (141.142.21.149)
> -1 * * * Timed out receiving responses
>Perhaps receiver 141.142.21.149 is not a member of group 224.2.177.155,
>or no router local to it has a route for source 140.221.9.172,
>or multicast at ttl 127 doesn't reach its last-hop router for that source
>(dyfrig) %
