We Believe: vBNS multicast works
Robert Olson
olson at mcs.anl.gov
Mon Jul 12 10:22:20 CDT 1999
>Now that Bill is under the impression that multicast IP works between BU
>and other places, can the other places see my transmission ???
>It is running from FENRIS.BU.EDU under the session name BOston
>University
Hm. We're seeing the session (at least I assume we're seeing it -- I'm at
home watching an rtpmon that shows that session with very little lossage,
but boston is showing some 80% lossages on its reception (that just went away).
Here are the mtraces. Again, one direction looks fine but the other isn't:
(dyfrig) % mtrace -t 127 dyfrig fenris.bu.edu 224.2.177.155
Mtrace from 140.221.9.172 to 128.197.160.83 via group 224.2.177.155
Querying full reverse path...
0 FENRIS.BU.EDU (128.197.160.83)
-1 CGLNET-GW.BU.EDU (128.197.160.1) DVMRP thresh^ 1
-2 DNS.BU.EDU (128.197.253.148) DVMRP thresh^ 4
-3 CRC-EXT-GW.BU.EDU (128.197.253.4) Unknown protocol code 8 thresh^ 0
-4 cs-atm0-0-12.cht.vbns.net (192.5.206.2) Unknown protocol code 8
thresh^ 0
-5 cs-atm1-0-4.dng.vbns.net (204.147.130.73) PIM/Static thresh^ 0
Reached RP/Core
-6 bluto-vbns.ctd.anl.gov (192.5.170.129) PIM thresh^ 32
-7 destiny.mcs.anl.gov (130.202.128.5) PIM thresh^ 6
-8 dyfrig.mcs.anl.gov (140.221.9.172)
Round trip time 100 ms; total ttl of 34 required.
Waiting to accumulate statistics... Results after 10 seconds:
Source Response Dest Overall Packet Statistics For Traffic From
140.221.9.172 224.0.1.32 Packet 140.221.9.172 To 224.2.177.155
v __/ rtt 374 ms Rate Lost/Sent = Pct Rate
140.221.11.253
130.202.128.5 destiny.mcs.anl.gov
v ^ ttl 7 632 pps 0/1 = --% 0 pps
130.202.128.1
192.5.170.129 bluto-vbns.ctd.anl.gov
v ^ ttl 34 219 pps 0/1 = --% 0 pps
192.5.170.130
204.147.130.73 cs-atm1-0-4.dng.vbns.net Reached RP/Core
v ^ ttl 34 313 pps 0/1 = --% 0 pps
204.147.130.74
192.5.206.2 cs-atm0-0-12.cht.vbns.net
v ^ ttl 34 315 pps 0/1 = --% 0 pps
192.5.206.1
128.197.253.4 CRC-EXT-GW.BU.EDU
v ^ ttl 34 262 pps 0/1 = --% 0 pps
128.197.253.148 DNS.BU.EDU
v ^ ttl 34 218 pps ?/1 0 pps
128.197.5.26
128.197.160.1 CGLNET-GW.BU.EDU
v \__ ttl 34 266 pps
128.197.160.83 140.221.9.172
Receiver Query Source
(dyfrig) % mtrace -t 127 fenris.bu.edu dyfrig 224.2.177.155
Mtrace from 128.197.160.83 to 140.221.9.172 via group 224.2.177.155
Querying full reverse path... * switching to hop-by-hop:
0 dyfrig.mcs.anl.gov (140.221.9.172)
-1 destiny-11.mcs.anl.gov (140.221.11.253) PIM thresh^ 6 [default]
-2 bluto.ctd.anl.gov (130.202.128.1) Unknown protocol code 8 thresh^ 0
Reached RP/Core
-3 cs-dng.anchor.anl.gov (192.5.170.130) Unknown protocol code 8
thresh^ 0 Reached RP/Core
-4 cs-atm0-0-12.cht.vbns.net (204.147.130.74) Unknown protocol code 8
thresh^ 0
-5 * * * * ? (192.5.206.1) didn't respond
-6 * * *
-7 * * *
-8 * * * ...giving up
Round trip time 219 ms; total ttl of 3 required.
Results after 39 seconds:
* * * 224.0.1.32 Packet 128.197.160.83 To 224.2.177.155
v __/ rtt 29 ms Rate Lost/Sent = Pct Rate
192.5.206.2
204.147.130.74 cs-atm0-0-12.cht.vbns.net
v ^ ttl 1 50 pps 2/1964 = 0% 50 pps
204.147.130.73
192.5.170.130 cs-dng.anchor.anl.gov Reached RP/Core
v ^ ttl 2 54 pps 9/1962 = 0% 50 pps
192.5.170.129
130.202.128.1 bluto.ctd.anl.gov
v ^ ttl 3 591 pps -6/1953 = 0% 50 pps
130.202.128.5
140.221.11.253 destiny-11.mcs.anl.gov
v \__ ttl 10 69 pps ?/1959 50 pps
140.221.9.172 140.221.9.172
