Unfiltered -- notes from today's post mortem
    Mark Hereld
    hereld at mcs.anl.gov
    Mon Aug 30 16:43:37 CDT 1999
>From: Mark Hereld <hereld at mcs.anl.gov>
>Subject: Fwd: Prelude to a Post Mortem
>>X-Sender: hereld at mcs.anl.gov
>>X-Mailer: QUALCOMM Windows Eudora Pro Version 4.2.0.58
>>Date: Mon, 30 Aug 1999 12:37:31 -0700
>>To: ag-tech at mcs.anl.gov
>>Subject: Prelude to a Post Mortem
>>Sender: owner-ag-tech at mcs.anl.gov
>>We're due for a post mortem of the Uky Chautauqua momentarily... 1 PM to
>>3 PM CDT.
>>Think about the following questions and see what you can come up with.
>>What did we do right? =====================================
>>() highly effective overall
>>() usually we had good communications
>>() particularly good use of backchannel to queue remote questions
>>() good use of backchannel to steer and correct dPPT problems
>() also, works best using a seperate server for dppt
>>Where did we have problems? ===============================
>>() router breakage
>>         - diagnosis time
>>         - work-around solution
>>         - time-to-fix
>() more bw in tests, to stress system before the chautauqua
>>() nestor audio breakage
>>         - power outage at anl
>                 nothing can be done about this..
>>         - audio (rat) funky state
>                 nestor wasn't using the std ag stuff -- used sdr
>>         - telecon operator puts nestor on hold!
>>         - patches to echo cancel hdwr not in place
>                 bu needs phone patch to the genter ready
>>         - potential cover w/ question from ncsa (melanie) bobbled
>>                 * argonne could hear melanie trying to break in w/ question
>>                 * uky had argonne and ncsa muted
>>                 * uky not looking at mud to see solutions
>                 -- russ says that local mc got the song going more or
> less right away
>                         and russ didn't have time to change the direction
> of the train
>         - communication to mc was problem...
>         - mc needs to be in contact w/ node operations
>                 * briefing -- train the mc to pay attention
>                 * somebody up near the mc w/ a headset to whisper stuff
>         - jennifer and margaret will dump a document describing tech comm
> skills
>>() more screen area definitely better
>>         - not ideal to have one screen split off and dedicated to dPPT
>>         - although it was better than only one screen
>         - comments said too many moving windows... confusing
>                 * choreographed animations might compress motion
>                 * preview tool would be useful for composition: then GO
>>() uky local headset comm
>>         - when is that appropriate?
>>         - did it conflict w/ backchannel comm?
>>         - is there a better way to use it?
>>                 * director/producer only to camera guys
>>                 * take node operators off that channel?
>         - russ said second headset was very useful
>         - johng found the local was crucial, but two headsets was too much
>         - russ, biggest problem was couldn't give too much info to the
> director or mc...
>                 * if mc decides to go in some direction ("can anybody
> sing?")
>                         then it doesn't matter what russ tries to tell them
>>() are there high priority technical issues to attack?
>>         - new software
>>         - better deployment schemes for urls, info, phone numbers, ppt
>> slides
>                 * russ is beginning to track down presenter slides
>>         - more practice on emergency handling?
>                 * mc could have some backup topics to talk about in case
> of probs
>                 * jennifer, in the audience, said the reaction was
> positive to the
>                         singing ad-lib
>                 * tom coffin suggests we stay on line and available
> during breaks
>                         so that folks can see and talk to the remote sights.
>                 * russ and all suggest: shorter version of script for
> node operators
>                 * wayne -- set names of ppt in advance....
>* mark suggests a video camera on ag-tech... to augment
>* jennifer says would facilitate 'meet the tech folk' session
