[AG-DEV] Access grid development environment set up
Andrew Ford
acf0659 at rit.edu
Mon Mar 16 15:30:29 CDT 2009
2009/3/16 Steve Saed <ssaed at iupui.edu>
> Where it says install ZSI, it means download ZSI from sourceforge and then
> build it using the setup.py script. Where should I put this ZSI?
It doesn't matter where you put it initially, when you run the setup script
it will copy files into your Python directory. It should look like this:
running install
running build
running build_py
creating build
creating build\lib
creating build\lib\ZSI
copying ZSI\address.py -> build\lib\ZSI
copying ZSI\auth.py -> build\lib\ZSI
copying ZSI\client.py -> build\lib\ZSI
copying ZSI\digest_auth.py -> build\lib\ZSI
copying ZSI\dispatch.py -> build\lib\ZSI
copying ZSI\fault.py -> build\lib\ZSI
copying ZSI\parse.py -> build\lib\ZSI
copying ZSI\resolvers.py -> build\lib\ZSI
copying ZSI\schema.py -> build\lib\ZSI
copying ZSI\ServiceContainer.py -> build\lib\ZSI
copying ZSI\ServiceProxy.py -> build\lib\ZSI
creating C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\address.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\auth.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\client.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\digest_auth.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\dispatch.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\fault.py -> C:\Python24\Lib\site-packages\ZSI
etc.
> Do I really need the code from the repository to set up the development
> environment?
If you want to modify the core Access Grid code, like the Venue Client, yes;
if it's something else, maybe not. What exactly are you trying to do?
--Andrew
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20090316/920bd156/attachment.htm>
