[AG-DEV] Access grid development environment set up
Andrew Ford
acf0659 at rit.edu
Mon Mar 16 11:19:38 CDT 2009
Hi Steve,
What error did ZSI give when you tried to install it? (ie, where exactly was
it looking for the interfaces folder?)
Also, what version of Python do you have, and do you have a normal
installation of Access Grid installed?
--Andrew
2009/3/12 Steve Saed <ssaed at iupui.edu>
> Hello,
> I am having hard time setting up the development environment for access
> grid. I downloaded all the packages necessary for the toolkit (Windows) as
> well as all the code on the repository.
> However, when I try to install the ZSI, it throws an error saying it cannot
> find the interfaces folder, so I just created that and it went past this
> error. Then, after i set the python search path, I ran the bootsrap.py
> script, it throws many errors not finding python scripts and some others
> related to cpp files (I am using Visual Studio 2008).
> Please email me if you have any feedback on that!
> Steve Saed
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20090316/8cfec960/attachment.htm>
