[AG-DEV] Access grid development environment set up
Steve Saed
ssaed at iupui.edu
Mon Mar 16 15:32:25 CDT 2009
I’ll let Meng explain this one for you! We will be trying to modify the venue client. So for that purpose, would I only need to python script of the venue client from the repository?
Thanks, I appreciate your help!
Steve
From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On Behalf Of Andrew Ford
Sent: Monday, March 16, 2009 4:30 PM
To: Steve Saed
Cc: Chuiyuan Meng; Scott Humphreys; ag-dev at mcs.anl.gov
Subject: Re: [AG-DEV] Access grid development environment set up
2009/3/16 Steve Saed <ssaed at iupui.edu>
Where it says install ZSI, it means download ZSI from sourceforge and then build it using the setup.py script. Where should I put this ZSI?
It doesn't matter where you put it initially, when you run the setup script it will copy files into your Python directory. It should look like this:
running install
running build
running build_py
creating build
creating build\lib
creating build\lib\ZSI
copying ZSI\address.py -> build\lib\ZSI
copying ZSI\auth.py -> build\lib\ZSI
copying ZSI\client.py -> build\lib\ZSI
copying ZSI\digest_auth.py -> build\lib\ZSI
copying ZSI\dispatch.py -> build\lib\ZSI
copying ZSI\fault.py -> build\lib\ZSI
copying ZSI\parse.py -> build\lib\ZSI
copying ZSI\resolvers.py -> build\lib\ZSI
copying ZSI\schema.py -> build\lib\ZSI
copying ZSI\ServiceContainer.py -> build\lib\ZSI
copying ZSI\ServiceProxy.py -> build\lib\ZSI
creating C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\address.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\auth.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\client.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\digest_auth.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\dispatch.py -> C:\Python24\Lib\site-packages\ZSI
copying build\lib\ZSI\fault.py -> C:\Python24\Lib\site-packages\ZSI
etc.
Do I really need the code from the repository to set up the development environment?
If you want to modify the core Access Grid code, like the Venue Client, yes; if it's something else, maybe not. What exactly are you trying to do?
--Andrew
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20090316/1fda19c9/attachment.htm>
