[AG-DEV] Re: Location of AG config files
Thomas D. Uram
turam at mcs.anl.gov
Thu Sep 11 07:55:05 CDT 2008
Chris:
What's the chance that a future change will also impact files under
/usr/share, requiring another adjustment? Is there any guidance from
the debian/ubuntu community about how to adjust, or where such files
should be placed?
> (One way around this would be to create a single mega-package of AG &
> related service packages, but I feel it would be an unsatisfying, if
> not "wrong", solution)
I agree that this is not the right way to go.
Tom
On 9/8/08 6:37 PM, Christoph Willing wrote:
> Tom,
> There is a problem with the Debian & Ubuntu AG packages. The revamped
> build tool mechanisms introduced early this year to accommodate
> multiple python versions on the same machine has an unfortunate side
> effect; anything under /etc is considered to be owned by a particular
> package and is removed completely during upgrades or reinstallations,
> regardless of whether another package may be using the same area.
> In the case of the AG installation, a number of configuration files
> are kept in directories under /etc/AccessGrid3. In particular,
> /etc/AccessGrid3/NodeServices normally contains the standard Audio &
> Video Services. However other packages may want to install services
> there too e.g. vpcscreen, aghdvic. Initial installation of these
> packages works OK but if the AG package is reinstalled or upgraded,
> the additional services are also removed.
> This (new) unwanted behaviour occurs because of the special treatment
> given to files/directories under /etc, so an solution is to use a
> different location. I have done some testing using
> /usr/share/AccessGrid3 instead of /etc/AccessGrid3 as a location for
> the config files. With this new location, any number of installations,
> reinstallations etc. of the AG & related packages can now be
> performed without any interference to each other. Introducing the new
> location is trivial - a single line patch to the toolkit code itself,
> as well as a single line change in the packaging script of each
> affected package (accessgrid3.x, vpcscreen, aghdvic, etc.)
> Since this is a Debian & Ubuntu specific problem, I don't expect that
> relocating /etc/AccessGrid3 needs to apply to all distributions
> (although it may be worth considering). However before I release any
> packages with the new file layout, do you have strong feelings about
> the proposed solution - or alternative solutions?
> I've cc'd to AG-DEV in case someone more conversant with Debian/Ubuntu
> Policies & packaging practices can offer advice; please chime in - I'm
> just a part-timer in this area and I'm keen to receive suggestions.
> chris
> Christoph Willing +617 3365 8350
> QCIF Access Grid Manager
> University of Queensland
