[AG-DEV] Location of AG config files
Jason Bell
j.bell at cqu.edu.au
Mon Sep 8 18:49:49 CDT 2008
Chris
Would this effect other Linux packages, such at Fedora?
Jason.
-----Original Message-----
From: Christoph Willing [mailto:c.willing at uq.edu.au]
Sent: Tuesday, 9 September 2008 09:38 AM
To: Thomas D. Uram
Cc: AG DEV
Subject: [AG-DEV] Location of AG config files
Tom,
There is a problem with the Debian & Ubuntu AG packages. The revamped
build tool mechanisms introduced early this year to accommodate
multiple python versions on the same machine has an unfortunate side
effect; anything under /etc is considered to be owned by a particular
package and is removed completely during upgrades or reinstallations,
regardless of whether another package may be using the same area.
In the case of the AG installation, a number of configuration files
are kept in directories under /etc/AccessGrid3. In particular, /etc/
AccessGrid3/NodeServices normally contains the standard Audio & Video
Services. However other packages may want to install services there
too e.g. vpcscreen, aghdvic. Initial installation of these packages
works OK but if the AG package is reinstalled or upgraded, the
additional services are also removed.
(One way around this would be to create a single mega-package of AG &
related service packages, but I feel it would be an unsatisfying, if
not "wrong", solution)
This (new) unwanted behaviour occurs because of the special treatment
given to files/directories under /etc, so an solution is to use a
different location. I have done some testing using /usr/share/
AccessGrid3 instead of /etc/AccessGrid3 as a location for the config
files. With this new location, any number of installations,
reinstallations etc. of the AG & related packages can now be
performed without any interference to each other. Introducing the new
location is trivial - a single line patch to the toolkit code itself,
as well as a single line change in the packaging script of each
affected package (accessgrid3.x, vpcscreen, aghdvic, etc.)
Since this is a Debian & Ubuntu specific problem, I don't expect that
relocating /etc/AccessGrid3 needs to apply to all distributions
(although it may be worth considering). However before I release any
packages with the new file layout, do you have strong feelings about
the proposed solution - or alternative solutions?
I've cc'd to AG-DEV in case someone more conversant with Debian/
Ubuntu Policies & packaging practices can offer advice; please chime
in - I'm just a part-timer in this area and I'm keen to receive
suggestions.
chris
Christoph Willing +617 3365 8350
QCIF Access Grid Manager
University of Queensland
