[AG-DEV] AG 3.2 RPM pre-beta SVN snapshots for Fedora and RHEL
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Jun 24 02:03:02 CDT 2008
As 'agpm --post-install' in the RPM postinstall step is creating the
~/.AccessGrid3/ dir and sub dirs when sudo is used, I might put in a
'su -c "agpm --post-install"' as a workaround which will cause it to
create ~root/.AccessGrid3 instead.
I'll modify the RPM once I'm back at work later in the week.
Doug
Christoph Willing wrote:
>>> I've noticed that a sudo quirk can be responsible for some entries
>>> (sometimes all entries) in .AccessGrid3 being owned by root.
>> Interesting. On install, I did a 'sudo rpm -Uvh AccessGrid...' from
>> an existing non root account. So the RPM install creates a
>> .AccessGrid3 subdirectory in the location the rpm command is run
>> from??? That seems unfortunate. Why is the rpm install even creating
>> these directories at all - it seems that those should be created on
>> VenuCelient launch if required.
> They'll be created by _any_ AG toolkit application, not just the
> VenueClient. The deb & tgz installers (Debian, Slackware, Ubuntu) all
> run a toolkit application (the AG package management tool) as part of
> the installation preocess. I'm not really familiar with the RPM
> installer and it may have a different mechanism altogether to register
> shared apps that are included in the toolkit itself, so my theory could
> be way off track.
> chris
>>> To avoid this, instead of using sudo by itself when installing etc.,
>>> use:
>>> sudo -H .....
>>> which ensures that new entries in .AccessGrid3 are owned by the user
>>> running sudo rather than root.
>> Great thx. I'll definitely use that.
>> Thanks everyone,
>> Todd
