[AG-DEV] AG 3.2 RPM pre-beta SVN snapshots for Fedora and RHEL
Christoph Willing
c.willing at uq.edu.au
Tue Jun 24 08:12:55 CDT 2008
On 24/06/2008, at 5:03 PM, Douglas Kosovic wrote:
> As 'agpm --post-install' in the RPM postinstall step is creating
> the ~/.AccessGrid3/ dir and sub dirs when sudo is used, I might put
> in a
> 'su -c "agpm --post-install"' as a workaround which will cause it
> to create ~root/.AccessGrid3 instead.
Good idea - then people won't have to remember any special options
for sudo.
chris
> I'll modify the RPM once I'm back at work later in the week.
> Doug
> Christoph Willing wrote:
>>>> I've noticed that a sudo quirk can be responsible for some
>>>> entries (sometimes all entries) in .AccessGrid3 being owned by
>>>> root.
>>> Interesting. On install, I did a 'sudo rpm -Uvh AccessGrid...'
>>> from an existing non root account. So the RPM install creates
>>> a .AccessGrid3 subdirectory in the location the rpm command is
>>> run from??? That seems unfortunate. Why is the rpm install even
>>> creating these directories at all - it seems that those should be
>>> created on VenuCelient launch if required.
>> They'll be created by _any_ AG toolkit application, not just the
>> VenueClient. The deb & tgz installers (Debian, Slackware, Ubuntu)
>> all run a toolkit application (the AG package management tool) as
>> part of the installation preocess. I'm not really familiar with
>> the RPM installer and it may have a different mechanism altogether
>> to register shared apps that are included in the toolkit itself,
>> so my theory could be way off track.
>> chris
>>>> To avoid this, instead of using sudo by itself when installing
>>>> etc., use:
>>>> sudo -H .....
>>>> which ensures that new entries in .AccessGrid3 are owned by the
>>>> user running sudo rather than root.
>>> Great thx. I'll definitely use that.
>>> Thanks everyone,
>>> Todd
Christoph Willing +617 3365 8350
QCIF Access Grid Manager
University of Queensland
