[AG-DEV] Re: Java Client for AG Server
Thomas D. Uram
turam at mcs.anl.gov
Wed Apr 9 10:22:45 CDT 2008
I've personally used PHPSOAP (PHP5) against the Access Grid components,
so I know that works.
This is the first I've heard of Java SOAP not working with the AG
components; I've had positive reports in the past. I believe this
should work, and could be made to work with some effort.
Andrew: Could you describe the problems that you encountered, that
convinced you to write a new SOAP implementation?
Tom
On 4/9/08 10:04 AM, Luis Galárraga wrote:
> Andrew and Thomas:
> I did not imagine that a custom soap messaging implementation would be
> necessary for that issue (in fact I thought we were omitting something
> important when trying with the other implementations). Doing it by
> ourselves would take several weeks of unplanned investigation and
> development, so thanks a lot for your really valuable help. We will
> just wait for your answer.
> Luis,
> 2008/4/9, Andrew Rowley <Andrew.Rowley at manchester.ac.uk
> <mailto:Andrew.Rowley at manchester.ac.uk>>:
> Hi,
> This was actually about the PHP SOAP interface (which also didn't
> work with the toolkit code), but the ideas are
> similar. Basically, I had to adapt what was there to produce the
> correct SOAP messages.
> Andrew :)
> Andrew G D Rowley
> Senior Development Officer
> Research Computing Services
> The University of Manchester
> Kilburn Building, Oxford Road
> Manchester, M13 9PL
> t : +44 (0) 161 275 0685
> e : Andrew.Rowley at manchester.ac.uk
> w : www.manchester.ac.uk/researchcomputing
> <http://www.manchester.ac.uk/researchcomputing>
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov <mailto:owner-ag-dev at mcs.anl.gov>
> [mailto:owner-ag-dev at mcs.anl.gov
> <mailto:owner-ag-dev at mcs.anl.gov>] On Behalf Of Thomas D. Uram
> Sent: 09 April 2008 00:21
> To: Luis Galárraga
> Cc: ag-dev at mcs.anl.gov <mailto:ag-dev at mcs.anl.gov>;
> openasel-commits at proyectossw.espol.edu.ec
> <mailto:openasel-commits at proyectossw.espol.edu.ec>; Marisol
> Villacrés; Ing. Verónica Macías
> Subject: [AG-DEV] Re: Java Client for AG Server
> Hi Luis:
> Some information from Andrew Rowley, one of the developers of
> Portal AG,
> about Java SOAP interfaces to the AG3 components is in this mail to
> ag-dev in 2006:
> http://www.mcs.anl.gov/web-mail-archive/lists/ag-dev/2006/10/msg00007.html
> I hope this helps,
> Tom
> On 4/8/08 6:11 PM, Luis Galárraga wrote:
> > AG developers:
> > As I exposed in other posts in this channel, a group of
> developers of
> > our project are working in making tests which consist in invoking
> > methods of VenueServer interface through SOAP and Java. All of our
> > tests with Java have been unsuccessful until now, however when using
> > ZSI to construct a client, we could easily make remote
> invocations in
> > our server. So my question is for people who is working in or knows
> > about Portal AccessGrid project, as part of its design includes
> a Java
> > Servlet which communicates with AG Server through SOAP. Which
> tool are
> > you using for that task?? I have tested with Axis and XFire with no
> > success (in the first case, I get a confusing error message when
> > making the remote call, with the second one, I could not
> generate the
> > proxy classes). Could you help me with more hints about that issue?
> > Thanks in advance,
> > Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080409/baa36a7a/attachment.htm>
