[AG-DEV] Java Client for AG Server
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Wed Apr 9 03:50:17 CDT 2008
Generator Microsoft Word 11 (filtered medium) Hi,
When doing this development, I could not find a SOAP implementation that worked with the AG Toolkit WSDL. We instead developed our own SOAP implementation and have adapted this over time so that it appears to work with all the AG Toolkit methods (well, the ones we use anyway!).
We will be releasing this shortly, including the source code, so you will be able to use it from within your program directly if you want to. I will have a look and see if I can package something up for you just now that you can use.
Andrew J
--------------------------------------------------------- Andrew G D Rowley Senior Development Officer Research Computing Services The University of Manchester Kilburn Building, Oxford Road Manchester, M13 9PL t : +44 (0) 161 275 0685 e : Andrew.Rowley at manchester.ac.uk w : www.manchester.ac.uk/researchcomputing ---------------------------------------------------------
From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Luis Galárraga Sent: 09 April 2008 00:12 To: ag-dev at mcs.anl.gov Cc: Thomas D. Uram; openasel-commits at proyectossw.espol.edu.ec; Marisol Villacrés; Ing. Verónica Macías Subject: [AG-DEV] Java Client for AG Server
AG developers: As I exposed in other posts in this channel, a group of developers of our project are working in making tests which consist in invoking methods of VenueServer interface through SOAP and Java. All of our tests with Java have been unsuccessful until now, however when using ZSI to construct a client, we could easily make remote invocations in our server. So my question is for people who is working in or knows about Portal AccessGrid project, as part of its design includes a Java Servlet which communicates with AG Server through SOAP. Which tool are you using for that task?? I have tested with Axis and XFire with no success (in the first case, I get a confusing error message when making the remote call, with the second one, I could not generate the proxy classes). Could you help me with more hints about that issue? Thanks in advance, Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080409/c3a21194/attachment.htm>
