[AG-DEV] Tapping into the video streams
lester leong
ihpcrcw at gmail.com
Mon Nov 12 01:14:49 CST 2007
Hi Andrew,
Thats right, I am running on Linux :-)
Cheers
lest
On Nov 9, 2007 9:13 PM, Andrew Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> Hi,
> Funny you should mention this - we seem to be having difficulty with receiving multicast locally on multicast sockets when using Java in linux. Is this the O/S you are using, or are you using windows? If windows, it should work. You may need to call socket.setLoopbackMode(false) to allow packets to loop back locally.
> If this is on linux, there may be a bug...
> Andrew :)
> Research Computing Services,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of lester leong
> Sent: 09 November 2007 12:55
> To: ag-dev at mcs.anl.gov
> Subject: [AG-DEV] Tapping into the video streams
> Greetings,
> I am new to AG and have been trying to see if I can tap into the rtp
> multicast session using my exising standalone viewer implemented with
> JMF (lets call it myViewer).
> If I run AG's VideoProducerService on machineA and use myViewer on
> machineB (with the multicast ip/port), I will be able to view the
> captured feeds on machineB. However, if run everything in one single
> machine, I will fail to receive any video feeds on myViewer. Any idea
> what could be blocking me from receiving my own feeds?
> Thanks in advance.
