[AG-DEV] Running AG3 From CVS on RHEL4 - Redux
Todd Zimmerman
toddz at sfu.ca
Thu Mar 16 15:44:08 CST 2006
Problems solved - thanks Doug!
Todd
Douglas Kosovic wrote:
> Hi Todd,
>> So, I completely wiped my CVS AG3 install and went with the rpm's that
>> Doug posted.
>> Most issues seem to have been solved; however, on the VenueServer
>> side, I'm still running into the
>> "TypeError: ssl_ctx_load_verify_locations() argument 2 must be string,
>> not None" error.
>> Tom mentioned it may be the version of Swig that was used - apparently
>> swig 1.3.24 fixes this issue.
>> Any suggestions??
> I've rebuilt m2crypto-0.15-3.fc3.i386.rpm with swig 1.3.24 on FC3, it
> can be found here:
> http://www.vislab.uq.edu.au/accessgrid3/fedora/3/i386/
> unfortunately it's got the same RPM revision number as the previous
> version that was up there, so you will need to 'rpm -e --nodeps
> m2crypto', then install the new one. I didn't increase the revison
> number because if I did, it would be greater than FC5's m2crypto and
> screw up upgrades from FC3 to FC5. Also fortunately, I haven't
> advertised that the FC3 RPMs are up yet.
> I haven't tested it myself yet.
> Cheers,
> Doug
