[AG-DEV] Running AG3 From CVS on RHEL4 - Redux
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Mar 15 22:30:23 CST 2006
Hi Todd,
> So, I completely wiped my CVS AG3 install and went with the rpm's that
> Doug posted.
> Most issues seem to have been solved; however, on the VenueServer side,
> I'm still running into the
> "TypeError: ssl_ctx_load_verify_locations() argument 2 must be string, not
> None" error.
> Tom mentioned it may be the version of Swig that was used - apparently
> swig 1.3.24 fixes this issue.
> Any suggestions??
I've rebuilt m2crypto-0.15-3.fc3.i386.rpm with swig 1.3.24 on FC3, it can be
found here:
http://www.vislab.uq.edu.au/accessgrid3/fedora/3/i386/
unfortunately it's got the same RPM revision number as the previous version
that was up there, so you will need to 'rpm -e --nodeps m2crypto', then
install the new one. I didn't increase the revison number because if I did,
it would be greater than FC5's m2crypto and screw up upgrades from FC3 to
FC5. Also fortunately, I haven't advertised that the FC3 RPMs are up yet.
I haven't tested it myself yet.
Cheers,
Doug
