[AG-DEV] AG3 VenueManagement can't connect
Christoph Willing
willing at itee.uq.edu.au
Fri Jan 20 14:37:59 CST 2006
On 21/01/2006, at 3:03 AM, Thomas D. Uram wrote:
> Is there mention of the default certificate in VenueManagement.log?
> If details there aren't clear, I'd sure be interested to see the log.
Tom,
A log of yesterday's attempts is attached. It includes attempts with
server running secure mode then insecure mode, although I don't know
if thats evident from the log. It also shows the different server
names used (localhost & fqdn).
The default certificate is mentioned a few times (at each start up I
guess). Since VenueServer and VenueManagement are running on the same
machine, each is using the same default cert, which mostly happens to
be a server certificiate, although you'll see near the end that I
also tried using an Anonymous User cert too.
chris
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20060121/bceb1df0/attachment.obj>
> On 1/19/06 10:25 PM, Christoph Willing wrote:
>> On 20/01/2006, at 2:01 PM, Thomas D. Uram wrote:
>>> Is your default certificate an identity certificate (i.e., does
>>> it require a passphrase?).
>>> That's not being handled currently. If so, try using a service
>>> certificate instead.
>>> If not, something's wrong.
>> Tom,
>> Its a VenueServer certificate, borrowed from another machine, and
>> same result using an anonymous certificate.
>> ag at v2:~$ certmgr.py
>> (ID mode) > list
>> 1. (Default) /O=Access Grid/OU=agdev-ca.mcs.anl.gov/
>> CN=VenueServer/ seivers.vislab.uq.edu.au
>> 2. /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
>> Anonymous Authority/CN=Anonymous User
>> 486c88f05354caa6e542b09b19cdee01
>> (ID mode) > show 1
>> Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/
>> Issuer: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
>> Developers CA
>> Certificate version: 2
>> Serial number: 5778
>> Not valid before: 03/18/05 01:41:35
>> Not valid after: 03/18/06 01:41:35
>> MD5 Fingerprint: 2A:81:9C:98:C2:76:09:1F:6C:E9:3E:47:B7:99:65:65
>> Certificate location: /home/ag/.AccessGrid3/Config/certRepo/
>> certificates/9c833de531fe7da7cff5bbfeaaf770fc/
>> 1c291311d25c9e1f2a79b98047ad6fec/cert.pem
>> Private key location: /home/ag/.AccessGrid3/Config/certRepo/
>> privatekeys/2f30fa4ccf0c09b08e4b9050829bc33b.pem
>>> On 1/19/06 7:30 PM, Christoph Willing wrote:
>>>> Working with a packaged AG3, I can run the VenueServer and
>>>> connect to it with a VenueClient. However I can't connect to
>>>> it with the VenueManagement tool. Trying to connect (from same
>>>> machine) with:
>>>> https://localhost/VenueServer
>>>> or https://v2.vislab.uq.edu.au/VenueServer
>>>> both immediately result in a "Unable To Connect" popup msg box
>>>> saying:
>>>> You were unable to connect to the venue server at:
>>>> https://v2.vislab.uq.edu.au/VenueServer.
>>>> The VenueServer.log doesn't mention anything about a
>>>> connection attempt in such cases.
>>>> If I then add a :8000 to the url, the following error is added
>>>> to VenueServer.log:
>>>> 01/20/06 11:27:29 -1273504848 Hosting ServiceContainer.py:
>>>> 146 ERROR None
>>>> Traceback (most recent call last):
>>>> File "/usr/lib/python2.4/site-packages/M2Crypto/SSL/
>>>> SSLServer.py", line 29, in handle_request
>>>> request, client_address = self.get_request()
>>>> File "/usr/lib/python2.4/SocketServer.py", line 373, in
>>>> get_request
>>>> return self.socket.accept()
>>>> Connection.py", line 114, in accept
>>>> ssl.accept_ssl()
>>>> Connection.py", line 103, in accept_ssl
>>>> return m2.ssl_accept(self.ssl)
>>>> SSLError: no certificate returned
>>>> Any ideas?
>>>> chris
>>>> Christoph Willing +61 7 3365 8350
>>>> QPSF Access Grid Manager
>>>> University of Queensland
