[AG-DEV] AG3 VenueManagement can't connect
Thomas D. Uram
turam at mcs.anl.gov
Fri Jan 20 14:53:06 CST 2006
Chris:
This line occurs repeatedly:
sslerror: (1, 'error:14094418:SSL routines:SSL3_READ_BYTES:tlsv1 alert unknown ca')
Do you have the appropriate CA certs in the cert repository?
I'm ignoring the 'connection refused' errors, because I expect either the
server wasn't
running, or was running on a different network interface.
Tom
On 1/20/06 2:37 PM, Christoph Willing wrote:
> On 21/01/2006, at 3:03 AM, Thomas D. Uram wrote:
>> Is there mention of the default certificate in VenueManagement.log?
>> If details there aren't clear, I'd sure be interested to see the log.
> Tom,
> A log of yesterday's attempts is attached. It includes attempts with
> server running secure mode then insecure mode, although I don't know if
> thats evident from the log. It also shows the different server names
> used (localhost & fqdn).
> The default certificate is mentioned a few times (at each start up I
> guess). Since VenueServer and VenueManagement are running on the same
> machine, each is using the same default cert, which mostly happens to
> be a server certificiate, although you'll see near the end that I also
> tried using an Anonymous User cert too.
> chris
>> On 1/19/06 10:25 PM, Christoph Willing wrote:
>>> On 20/01/2006, at 2:01 PM, Thomas D. Uram wrote:
>>>> Is your default certificate an identity certificate (i.e., does it
>>>> require a passphrase?).
>>>> That's not being handled currently. If so, try using a service
>>>> certificate instead.
>>>> If not, something's wrong.
>>> Tom,
>>> Its a VenueServer certificate, borrowed from another machine, and
>>> same result using an anonymous certificate.
>>> ag at v2:~$ certmgr.py
>>> (ID mode) > list
>>> 1. (Default) /O=Access Grid/OU=agdev-ca.mcs.anl.gov/ CN=VenueServer/
>>> seivers.vislab.uq.edu.au
>>> 2. /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
>>> Anonymous Authority/CN=Anonymous User 486c88f05354caa6e542b09b19cdee01
>>> (ID mode) > show 1
>>> Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/
>>> Issuer: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
>>> Developers CA
>>> Certificate version: 2
>>> Serial number: 5778
>>> Not valid before: 03/18/05 01:41:35
>>> Not valid after: 03/18/06 01:41:35
>>> MD5 Fingerprint: 2A:81:9C:98:C2:76:09:1F:6C:E9:3E:47:B7:99:65:65
>>> Certificate location: /home/ag/.AccessGrid3/Config/certRepo/
>>> certificates/9c833de531fe7da7cff5bbfeaaf770fc/
>>> 1c291311d25c9e1f2a79b98047ad6fec/cert.pem
>>> Private key location: /home/ag/.AccessGrid3/Config/certRepo/
>>> privatekeys/2f30fa4ccf0c09b08e4b9050829bc33b.pem
>>>> On 1/19/06 7:30 PM, Christoph Willing wrote:
>>>>> Working with a packaged AG3, I can run the VenueServer and
>>>>> connect to it with a VenueClient. However I can't connect to it
>>>>> with the VenueManagement tool. Trying to connect (from same
>>>>> machine) with:
>>>>> https://localhost/VenueServer
>>>>> or https://v2.vislab.uq.edu.au/VenueServer
>>>>> both immediately result in a "Unable To Connect" popup msg box
>>>>> saying:
>>>>> You were unable to connect to the venue server at:
>>>>> https://v2.vislab.uq.edu.au/VenueServer.
>>>>> The VenueServer.log doesn't mention anything about a connection
>>>>> attempt in such cases.
>>>>> If I then add a :8000 to the url, the following error is added
>>>>> to VenueServer.log:
>>>>> 01/20/06 11:27:29 -1273504848 Hosting ServiceContainer.py:
>>>>> 146 ERROR None
>>>>> Traceback (most recent call last):
>>>>> File "/usr/lib/python2.4/site-packages/M2Crypto/SSL/
>>>>> SSLServer.py", line 29, in handle_request
>>>>> request, client_address = self.get_request()
>>>>> File "/usr/lib/python2.4/SocketServer.py", line 373, in get_request
>>>>> return self.socket.accept()
>>>>> Connection.py", line 114, in accept
>>>>> ssl.accept_ssl()
>>>>> Connection.py", line 103, in accept_ssl
>>>>> return m2.ssl_accept(self.ssl)
>>>>> SSLError: no certificate returned
>>>>> Any ideas?
>>>>> chris
>>>>> Christoph Willing +61 7 3365 8350
>>>>> QPSF Access Grid Manager
>>>>> University of Queensland
