[AG-DEV] AG3 VenueManagement can't connect
Thomas D. Uram
turam at mcs.anl.gov
Fri Jan 20 11:03:42 CST 2006
Is there mention of the default certificate in VenueManagement.log?
If details there aren't clear, I'd sure be interested to see the log.
Tom
On 1/19/06 10:25 PM, Christoph Willing wrote:
> On 20/01/2006, at 2:01 PM, Thomas D. Uram wrote:
>> Is your default certificate an identity certificate (i.e., does it
>> require a passphrase?).
>> That's not being handled currently. If so, try using a service
>> certificate instead.
>> If not, something's wrong.
> Tom,
> Its a VenueServer certificate, borrowed from another machine, and same
> result using an anonymous certificate.
> ag at v2:~$ certmgr.py
> (ID mode) > list
> 1. (Default) /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/
> seivers.vislab.uq.edu.au
> 2. /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
> Anonymous Authority/CN=Anonymous User 486c88f05354caa6e542b09b19cdee01
> (ID mode) > show 1
> Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/
> Issuer: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
> Developers CA
> Certificate version: 2
> Serial number: 5778
> Not valid before: 03/18/05 01:41:35
> Not valid after: 03/18/06 01:41:35
> MD5 Fingerprint: 2A:81:9C:98:C2:76:09:1F:6C:E9:3E:47:B7:99:65:65
> Certificate location: /home/ag/.AccessGrid3/Config/certRepo/
> certificates/9c833de531fe7da7cff5bbfeaaf770fc/
> 1c291311d25c9e1f2a79b98047ad6fec/cert.pem
> Private key location: /home/ag/.AccessGrid3/Config/certRepo/
> privatekeys/2f30fa4ccf0c09b08e4b9050829bc33b.pem
>> On 1/19/06 7:30 PM, Christoph Willing wrote:
>>> Working with a packaged AG3, I can run the VenueServer and connect
>>> to it with a VenueClient. However I can't connect to it with the
>>> VenueManagement tool. Trying to connect (from same machine) with:
>>> https://localhost/VenueServer
>>> or https://v2.vislab.uq.edu.au/VenueServer
>>> both immediately result in a "Unable To Connect" popup msg box saying:
>>> You were unable to connect to the venue server at:
>>> https://v2.vislab.uq.edu.au/VenueServer.
>>> The VenueServer.log doesn't mention anything about a connection
>>> attempt in such cases.
>>> If I then add a :8000 to the url, the following error is added to
>>> VenueServer.log:
>>> 01/20/06 11:27:29 -1273504848 Hosting ServiceContainer.py:146
>>> ERROR None
>>> Traceback (most recent call last):
>>> File "/usr/lib/python2.4/site-packages/M2Crypto/SSL/
>>> SSLServer.py", line 29, in handle_request
>>> request, client_address = self.get_request()
>>> File "/usr/lib/python2.4/SocketServer.py", line 373, in get_request
>>> return self.socket.accept()
>>> Connection.py", line 114, in accept
>>> ssl.accept_ssl()
>>> Connection.py", line 103, in accept_ssl
>>> return m2.ssl_accept(self.ssl)
>>> SSLError: no certificate returned
>>> Any ideas?
>>> chris
>>> Christoph Willing +61 7 3365 8350
>>> QPSF Access Grid Manager
>>> University of Queensland
