[AG-DEV] AG3 VenueManagement can't connect
Christoph Willing
willing at itee.uq.edu.au
Thu Jan 19 22:25:12 CST 2006
On 20/01/2006, at 2:01 PM, Thomas D. Uram wrote:
> Is your default certificate an identity certificate (i.e., does it
> require a passphrase?).
> That's not being handled currently. If so, try using a service
> certificate instead.
> If not, something's wrong.
Tom,
Its a VenueServer certificate, borrowed from another machine, and
same result using an anonymous certificate.
ag at v2:~$ certmgr.py
(ID mode) > list
1. (Default) /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/
seivers.vislab.uq.edu.au
2. /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
Anonymous Authority/CN=Anonymous User 486c88f05354caa6e542b09b19cdee01
(ID mode) > show 1
Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/
Issuer: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
Developers CA
Certificate version: 2
Serial number: 5778
Not valid before: 03/18/05 01:41:35
Not valid after: 03/18/06 01:41:35
MD5 Fingerprint: 2A:81:9C:98:C2:76:09:1F:6C:E9:3E:47:B7:99:65:65
Certificate location: /home/ag/.AccessGrid3/Config/certRepo/
certificates/9c833de531fe7da7cff5bbfeaaf770fc/
1c291311d25c9e1f2a79b98047ad6fec/cert.pem
Private key location: /home/ag/.AccessGrid3/Config/certRepo/
privatekeys/2f30fa4ccf0c09b08e4b9050829bc33b.pem
> On 1/19/06 7:30 PM, Christoph Willing wrote:
>> Working with a packaged AG3, I can run the VenueServer and connect
>> to it with a VenueClient. However I can't connect to it with the
>> VenueManagement tool. Trying to connect (from same machine) with:
>> https://localhost/VenueServer
>> or https://v2.vislab.uq.edu.au/VenueServer
>> both immediately result in a "Unable To Connect" popup msg box
>> saying:
>> You were unable to connect to the venue server at:
>> https://v2.vislab.uq.edu.au/VenueServer.
>> The VenueServer.log doesn't mention anything about a connection
>> attempt in such cases.
>> If I then add a :8000 to the url, the following error is added to
>> VenueServer.log:
>> 01/20/06 11:27:29 -1273504848 Hosting ServiceContainer.py:146
>> ERROR None
>> Traceback (most recent call last):
>> File "/usr/lib/python2.4/site-packages/M2Crypto/SSL/
>> SSLServer.py", line 29, in handle_request
>> request, client_address = self.get_request()
>> File "/usr/lib/python2.4/SocketServer.py", line 373, in get_request
>> return self.socket.accept()
>> Connection.py", line 114, in accept
>> ssl.accept_ssl()
>> Connection.py", line 103, in accept_ssl
>> return m2.ssl_accept(self.ssl)
>> SSLError: no certificate returned
>> Any ideas?
>> chris
>> Christoph Willing +61 7 3365 8350
>> QPSF Access Grid Manager
>> University of Queensland
