[AG-DEV] Node Services configurable options ...
Thomas D. Uram
turam at mcs.anl.gov
Thu Aug 11 01:44:17 CDT 2005
I would like to have that additional type. I tried to build it once,
but gave up because the browsing internals of FileDialog are down in the
C layer, and I didn't have time to build my own FileDialog with custom
(remote) browsing functionality.
If someone wants to contribute such functionality, I'd be happy to take
it. The timeline for 2.4 is too short at this point, however, so it
would have to go in a release post 2.4.
Tom
Darran Edmundson wrote:
> In the node services manual:
> http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/
> NODE_SERVICES_MANUAL/ProgrammersManual_NodeServices.htm
> the types of
> OptionSetParameter(name, defaultOption, optionsList) - The optionsList
> will be displayed in a dropdown menu with defaultOption set as default.
> RangeParameter(name, initialValue, startValue, stopValue) – Shows a
> slider with startValue as minimum value and stopValue as maximum value.
> The initialValue will be the starting point for the slider.
> TextParameter(name, value) – Represents a text field set to value as a
> string.
> ValueParameter() – Represents a integer field set to value as an integer.
> For the maintenance release of AG 2.x, any chance of getting a
> wx.FileDialog
> chooser added to the list?
> Cheers,
> Darran.
> Darran Edmundson (darran.edmundson at anu.edu.au)
> ANU Supercomputer Facility Vizlab
> Australian National University, Canberra, ACT 2600
> tel: +61 2 6125-0517 fax: +61 2 6125-5088
