[AG-DEV] Node Services configurable options ...
Darran Edmundson
darran.edmundson at anu.edu.au
Mon Aug 8 21:12:11 CDT 2005
In the node services manual:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/
NODE_SERVICES_MANUAL/ProgrammersManual_NodeServices.htm
the types of
OptionSetParameter(name, defaultOption, optionsList) - The
optionsList will be displayed in a dropdown menu with defaultOption
set as default.
RangeParameter(name, initialValue, startValue, stopValue) – Shows a
slider with startValue as minimum value and stopValue as maximum
value. The initialValue will be the starting point for the slider.
TextParameter(name, value) – Represents a text field set to value as
a string.
ValueParameter() – Represents a integer field set to value as an
integer.
For the maintenance release of AG 2.x, any chance of getting a
wx.FileDialog
chooser added to the list?
Cheers,
Darran.
Darran Edmundson (darran.edmundson at anu.edu.au)
ANU Supercomputer Facility Vizlab
Australian National University, Canberra, ACT 2600
tel: +61 2 6125-0517 fax: +61 2 6125-5088
