Fwd: Testing Access Grid node (fwd)
Susanne Lefvert
lefvert at mcs.anl.gov
Tue Nov 30 13:43:20 CST 2004
Fyi, I got this from Roger.
Susanne,
I moved the machine outside of our firewall, it seems to be working. My
Network Admin will do a trace this afternoon.
I appreciate the time and effort you've put into this.
Roger S.
AOD-IT
630 252-9929
On Wed, 24 Nov 2004, Susanne Lefvert wrote:
> Roger Sersted (a System Administrator at the APS) has problems connecting
> to vv2. What could cause this exception? Any ideas?
> 11/12/2004 02:18:01 PM -150546944 TextConnection __init__.py:988 ERROR
> Couldn't connect to text service! hume.mcs.anl.gov:9004
> Traceback (most recent call last):
> File "/usr/lib/python2.3/site-packages/AccessGrid/TextClient.py", line
> 133, in __init__
> self.socket.connect(self.host, self.port, self.attr)
> File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 990, in
> connect
> raise ex
> GSITCPSocketException: an end-of-file was reached
> Thanks,
> Susanne
> ---------- Forwarded message ----------
> Date: Fri, 12 Nov 2004 14:34:11 -0600
> From: Roger Sersted <rs1 at aps.anl.gov>
> To: Susanne Lefvert <lefvert at mcs.anl.gov>
> Subject: Re: Fwd: Testing Access Grid node (fwd)
> Susanne,
> Now that I know where the AG logs are (didn't before). I was able to at
> least do some work on my own. Anyway, I also talked to my Network Admin
> and he opened some additional ports on the firewall for the AG software,
> 9000-9011 and 11000. This was based on another User's AG setup and our
> APS firewall logs. I have had some success, but there seems to be a
> piece of the puzzle missing.
> The symptoms: In the venue client, I go to the default test venue and I
> still get the message "unable to connect to Venue server", but my name
> is listed as a "participant". I could even see other participants, but
> every other indication is that I'm not in the venue. I'm confused.
> The AG2.3 software is installed on RedHat Linux Fedora Core 2. I've
> attached the VenueClient.log and VideoConsumerService.log. These are
> the only logs written when I run the client. Hopefully, they provide
> some insight.
> Thanks,
> Roger S.
> > Roger,
> > I am connected to the vv2 server right now. You can also try the ncsa
> > venue server at https://venues.ncsa.uiuc.edu:9000/Venues/default. These
> > servers should be up all day so you can connect whenever you want. Some
> > questions:
> > * What operating system are you using?
> > * Which version of the Access Grid toolkit are you running?
> > * Is your machine clock correct? Otherwise, it may appear like your
> > certificate has expired even though it is still valid.
> > Could you also attach your log file (for windows) C:\Documents and
> > Settings\<user>\Application Data\AccessGrid\Logs\VenueClient (for linux)
> > .AccessGrid/Logs/VenueClient.
> > Thanks,
> > Susanne
