Fwd: Testing Access Grid node (fwd)
Susanne Lefvert
lefvert at mcs.anl.gov
Wed Nov 24 09:37:29 CST 2004
Roger Sersted (a System Administrator at the APS) has problems connecting
to vv2. What could cause this exception? Any ideas?
11/12/2004 02:18:01 PM -150546944 TextConnection __init__.py:988 ERROR
Couldn't connect to text service! hume.mcs.anl.gov:9004
Traceback (most recent call last):
File "/usr/lib/python2.3/site-packages/AccessGrid/TextClient.py", line
133, in __init__
self.socket.connect(self.host, self.port, self.attr)
File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 990, in
connect
raise ex
GSITCPSocketException: an end-of-file was reached
Susanne
---------- Forwarded message ----------
Date: Fri, 12 Nov 2004 14:34:11 -0600
To: Susanne Lefvert <lefvert at mcs.anl.gov>
Subject: Re: Fwd: Testing Access Grid node (fwd)
Susanne,
Now that I know where the AG logs are (didn't before). I was able to at
least do some work on my own. Anyway, I also talked to my Network Admin
and he opened some additional ports on the firewall for the AG software,
9000-9011 and 11000. This was based on another User's AG setup and our
APS firewall logs. I have had some success, but there seems to be a
piece of the puzzle missing.
The symptoms: In the venue client, I go to the default test venue and I
still get the message "unable to connect to Venue server", but my name
is listed as a "participant". I could even see other participants, but
every other indication is that I'm not in the venue. I'm confused.
The AG2.3 software is installed on RedHat Linux Fedora Core 2. I've
attached the VenueClient.log and VideoConsumerService.log. These are
the only logs written when I run the client. Hopefully, they provide
some insight.
Roger S.
Susanne Lefvert wrote:
> Roger,
> I am connected to the vv2 server right now. You can also try the ncsa
> venue server at https://venues.ncsa.uiuc.edu:9000/Venues/default. These
> servers should be up all day so you can connect whenever you want. Some
> questions:
> * What operating system are you using?
> * Which version of the Access Grid toolkit are you running?
> * Is your machine clock correct? Otherwise, it may appear like your
> certificate has expired even though it is still valid.
> Could you also attach your log file (for windows) C:\Documents and
> Settings\<user>\Application Data\AccessGrid\Logs\VenueClient (for linux)
> .AccessGrid/Logs/VenueClient.
> Thanks,
> Susanne
11/12/04 14:17:49 -150252032 ProxyGen __init__.py:988 DEBUG Using GT24 proxy code
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 DEBUG Initializing AG Toolkit version 2.3
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 INFO Logfile Name: VideoConsumerService.log
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 INFO Service init: have profile None
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG Opened repository /home/phoebus/RS1/.AccessGrid/Config/certRepo
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 INFO Initialized cert mgmt.
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 INFO Loaded profile and configured with it.
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG Configuring standard environment
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG Looking for identity (unused) None
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG Proxy /tmp/x509up_u153 will expire 11/12/04 21:36:06
11/12/04 14:17:50 -150252032 CertificateManager __init__.py:988 DEBUG done, success=1
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 INFO Initialized Globus.
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 INFO Service Initialization Complete.
11/12/04 14:17:50 -150252032 Toolkit __init__.py:988 INFO Starting Service URI: https://pcdiag11.aps.anl.gov:60702/Service
11/12/2004 02:17:45 PM -150546944 ProxyGen __init__.py:988 DEBUG Using GT24 proxy code
11/12/2004 02:17:46 PM -150546944 Toolkit __init__.py:988 DEBUG Initializing AG Toolkit version 2.3
11/12/2004 02:17:47 PM -150546944 Platform __init__.py:988 INFO registering file type .agpkg with gnome
11/12/2004 02:17:47 PM -150546944 Platform __init__.py:988 INFO registering file type .vv2d with gnome
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 INFO Logfile Name: VenueClient.log
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG System hostname of pcdiag11.aps.anl.gov is valid
11/12/2004 02:17:47 PM -150546944 CertificateManager __init__.py:988 DEBUG Opened repository /home/phoebus/RS1/.AccessGrid/Config/certRepo
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Got repo.
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG looking in system ca dir: /etc/AccessGrid/Config/CAcertificates
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Getting cert: d1b603c3.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 WARNING Not importing cert /etc/AccessGrid/Config/CAcertificates/d1b603c3.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Getting cert: 1c3f2ca8.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 WARNING Not importing cert /etc/AccessGrid/Config/CAcertificates/1c3f2ca8.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Getting cert: 45cc9e80.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 WARNING Not importing cert /etc/AccessGrid/Config/CAcertificates/45cc9e80.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Getting cert: f18fa857.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 WARNING Not importing cert /etc/AccessGrid/Config/CAcertificates/f18fa857.0
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Init'ing globus.
11/12/2004 02:17:47 PM -150546944 CertificateManager __init__.py:988 DEBUG Configuring standard environment
11/12/2004 02:17:47 PM -150546944 CertificateManager __init__.py:988 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted
11/12/2004 02:17:47 PM -150546944 CertificateManager __init__.py:988 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted
11/12/2004 02:17:47 PM -150546944 CertificateManager __init__.py:988 DEBUG Looking for identity (unused) None
11/12/2004 02:17:47 PM -150546944 CertificateManager __init__.py:988 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted
11/12/2004 02:17:47 PM -150546944 CertificateManager __init__.py:988 DEBUG Proxy /tmp/x509up_u153 will expire 11/12/2004 09:36:06 PM
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Done with globus.
11/12/2004 02:17:47 PM -150546944 VenueClient __init__.py:988 DEBUG __StartWebService: venueclient: https://pcdiag11.aps.anl.gov:11000/VenueClient
11/12/2004 02:17:47 PM -150546944 ServiceManager __init__.py:988 INFO Using services dir: /home/phoebus/RS1/.AccessGrid/local_services
11/12/2004 02:17:47 PM -150546944 ServiceManager __init__.py:988 INFO __DiscoverResources
11/12/2004 02:17:47 PM -150546944 Platform __init__.py:988 INFO open: [Errno 13] Permission denied: '/dev/video1'
11/12/2004 02:17:47 PM -150546944 Platform __init__.py:988 INFO open: [Errno 13] Permission denied: '/dev/video3'
11/12/2004 02:17:47 PM -150546944 Platform __init__.py:988 INFO open: [Errno 13] Permission denied: '/dev/video2'
11/12/2004 02:17:47 PM -150546944 Platform __init__.py:988 INFO open: [Errno 13] Permission denied: '/dev/video0'
11/12/2004 02:17:47 PM -150546944 VenueClient __init__.py:988 DEBUG __StartWebService: service manager: https://pcdiag11.aps.anl.gov:11000/ServiceManager
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO NodeService.__ReadConfigFile
11/12/2004 02:17:47 PM -150546944 Toolkit __init__.py:988 DEBUG Looking for: /home/phoebus/RS1/.AccessGrid/Config/AGNodeService.cfg
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 DEBUG DEFAULT NODE SERVICE CONFIG: /home/phoebus/RS1/.AccessGrid/Config/AGNodeService.cfg
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO Reading node service config file: /home/phoebus/RS1/.AccessGrid/Config/AGNodeService.cfg
11/12/2004 02:17:47 PM -150546944 VenueClient __init__.py:988 DEBUG __StartWebService: node service: https://pcdiag11.aps.anl.gov:11000/NodeService
11/12/2004 02:17:47 PM -150546944 VenueClient __init__.py:988 DEBUG SerNodeUrl: Set node service url: https://pcdiag11.aps.anl.gov:11000/NodeService
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO NodeService.GetDefaultConfiguration
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO Migration unnecessary
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO NodeService.LoadDefaultConfig
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO Loading default node configuration: Initial_testing
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO NodeService.LoadConfiguration
11/12/2004 02:17:47 PM -150546944 NodeService __init__.py:988 INFO Trying to load node configuration from: /home/phoebus/RS1/.AccessGrid/Config/nodeConfig/Initial_testing
11/12/2004 02:17:48 PM 1436048304 ServiceManager __init__.py:988 INFO AGServiceManager.RemoveServices
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 INFO AGServiceManager.AddService
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 INFO AddService: VideoConsumerService v 2.300000 u VideoConsumerService.zip
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 INFO resourceToAssign:
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 DEBUG ** Resource does not exist! :
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 INFO Retaining version 2.300000
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 INFO Extracting service package to /home/phoebus/RS1/.AccessGrid/local_services/VideoConsumerService
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 INFO Running Service; options: /usr/bin/python2 ['/home/phoebus/RS1/.AccessGrid/local_services/VideoConsumerService/VideoConsumerService.py', 60702]
11/12/2004 02:17:49 PM 1436048304 ServiceManager __init__.py:988 DEBUG Waiting for service to start: VideoConsumerService https://pcdiag11.aps.anl.gov:60702/Service
11/12/2004 02:17:51 PM 1436048304 ServiceManager __init__.py:988 INFO Service VideoConsumerService successfully started
11/12/2004 02:17:51 PM 1436048304 ServiceManager __init__.py:988 DEBUG Not setting service configuration; none given
11/12/2004 02:17:51 PM 1436048304 ServiceManager __init__.py:988 DEBUG Not assigning resource; none given
11/12/2004 02:17:51 PM -150546944 NodeService __init__.py:988 INFO Not setting identity for service VideoConsumerService; no profile
11/12/2004 02:17:51 PM -150546944 VenueClient __init__.py:988 DEBUG __createPersonalDataStore: Creating personal datastore at /home/phoebus/RS1/.AccessGrid/Config/personalDataStore using prefix personalDataStore and port 0
11/12/2004 02:17:51 PM -150546944 DataStore __init__.py:988 DEBUG Creating thread 0
11/12/2004 02:17:51 PM -150546944 DataStore __init__.py:988 DEBUG Starting thread 0
11/12/2004 02:17:51 PM -150546944 DataStore __init__.py:988 DEBUG Waiting thread 0
11/12/2004 02:17:51 PM 1436048304 DataStore __init__.py:988 DEBUG Worker 0 starting
11/12/2004 02:17:51 PM -150546944 DataStore __init__.py:988 DEBUG Done creating workers
11/12/2004 02:17:51 PM -150546944 DataStore __init__.py:988 DEBUG Reading persisted data from: /home/phoebus/RS1/.AccessGrid/Config/personalDataStore/DataStore.dat
11/12/2004 02:17:51 PM -150546944 VenueClient __init__.py:988 DEBUG __createPersonalDataStore: Load personal data from file
11/12/2004 02:17:51 PM -150546944 VenueClientController __init__.py:988 DEBUG There is no personal venues file to load.
11/12/2004 02:17:56 PM -150546944 VenueClient __init__.py:988 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
11/12/2004 02:17:56 PM -150546944 CertificateManager __init__.py:988 DEBUG Looking for identity (unused) None
11/12/2004 02:17:56 PM -150546944 CertificateManager __init__.py:988 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted/CN=proxy
11/12/2004 02:17:56 PM 1457028016 NodeService __init__.py:988 INFO NodeService.GetCapabilities
11/12/2004 02:17:56 PM 1457028016 NodeService __init__.py:988 INFO NodeService.GetServices
11/12/2004 02:17:57 PM 1467517872 ServiceManager __init__.py:988 INFO AGServiceManager.GetServices
11/12/2004 02:17:57 PM -150546944 VenueClient __init__.py:988 DEBUG EnterVenue: Invoke venue enter
11/12/2004 02:18:00 PM -150546944 EventClient __init__.py:988 DEBUG Have callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:18:01 PM -150546944 TextConnection __init__.py:988 ERROR Couldn't connect to text service! hume.mcs.anl.gov:9004
File "/usr/lib/python2.3/site-packages/AccessGrid/TextClient.py", line 133, in __init__
File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 990, in connect
raise ex
11/12/2004 02:18:01 PM -150546944 VenueClient __init__.py:988 ERROR EnterVenue: failed
File "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py", line 834, in EnterVenue
self.__EnterVenue(URL)
File "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py", line 777, in __EnterVenue
self.venueState.textLocation)
File "/usr/lib/python2.3/site-packages/AccessGrid/TextClient.py", line 270, in __init__
self.textProcessor)
File "/usr/lib/python2.3/site-packages/AccessGrid/TextClient.py", line 137, in __init__
raise TextClientConnectException
11/12/2004 02:18:01 PM -150546944 VenueClient __init__.py:988 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
11/12/2004 02:18:01 PM -150546944 VenueClient __init__.py:988 DEBUG warningString:
11/12/2004 02:18:34 PM -150546944 VenueClient __init__.py:988 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
11/12/2004 02:18:34 PM -150546944 CertificateManager __init__.py:988 DEBUG Looking for identity (unused) None
11/12/2004 02:18:34 PM -150546944 CertificateManager __init__.py:988 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=rs-1.com/CN=Roger Sersted/CN=proxy
11/12/2004 02:18:34 PM 1478007728 NodeService __init__.py:988 INFO NodeService.GetCapabilities
11/12/2004 02:18:34 PM 1478007728 NodeService __init__.py:988 INFO NodeService.GetServices
11/12/2004 02:18:34 PM 1488497584 ServiceManager __init__.py:988 INFO AGServiceManager.GetServices
11/12/2004 02:18:35 PM -150546944 VenueClient __init__.py:988 DEBUG EnterVenue: Invoke venue enter
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _c88d1d0a_p_callbackStruct within callback
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=1655
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG finally read enough data, wait=1655 buflen=1655
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:18:36 PM 30493616 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:18:36 PM 1457028016 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:18:38 PM -150546944 EventClient __init__.py:988 DEBUG Have callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:18:39 PM -150546944 TextConnection __init__.py:988 ERROR Couldn't connect to text service! hume.mcs.anl.gov:9004
raise ex
11/12/2004 02:18:39 PM -150546944 VenueClient __init__.py:988 ERROR EnterVenue: failed
self.textProcessor)
11/12/2004 02:18:39 PM -150546944 VenueClient __init__.py:988 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
11/12/2004 02:18:39 PM -150546944 VenueClient __init__.py:988 DEBUG warningString:
11/12/2004 02:18:39 PM 1457028016 VenueClient __init__.py:988 DEBUG add user: Roger Sersted
11/12/2004 02:18:39 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Roger Sersted (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _c88d1d0a_p_callbackStruct within callback
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=2181
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG finally read enough data, wait=2181 buflen=2181
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:19:11 PM 1457028016 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:19:11 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant DIII-D National Fusion Facility Test (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:19:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=2181
11/12/2004 02:19:11 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:19:11 PM 1457028016 VenueClient __init__.py:988 DEBUG add user: DIII-D National Fusion Facility Test
11/12/2004 02:19:12 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: DIII-D National Fusion Facility Test
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _c88d1d0a_p_callbackStruct within callback
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=1919
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG finally read enough data, wait=1919 buflen=1919
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:19:34 PM 1457028016 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:19:34 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kristof Ostir (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:19:34 PM 1457028016 VenueClient __init__.py:988 DEBUG add user: Kristof Ostir
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:19:34 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1919
11/12/2004 02:19:34 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:19:34 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Kristof Ostir
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1918
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG finally read enough data, wait=1918 buflen=1918
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:20:08 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:20:08 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Kristof Ostir
11/12/2004 02:20:08 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:20:08 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:20:08 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:20:08 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:20:08 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:20:08 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _c88d1d0a_p_callbackStruct within callback
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:20:08 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=1918
11/12/2004 02:20:08 PM 1457028016 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:20:08 PM 1457028016 VenueClient __init__.py:988 DEBUG remove user: Kristof Ostir
11/12/2004 02:20:08 PM 1457028016 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1919
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG finally read enough data, wait=1919 buflen=1919
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:20:30 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:20:30 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kristof Ostir (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:20:30 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Kristof Ostir
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _c88d1d0a_p_callbackStruct within callback
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:20:30 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=1919
11/12/2004 02:20:30 PM 1457028016 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:20:30 PM 1457028016 VenueClient __init__.py:988 DEBUG add user: Kristof Ostir
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1918
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG finally read enough data, wait=1918 buflen=1918
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:21:11 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:21:11 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Kristof Ostir
11/12/2004 02:21:11 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:21:11 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:21:11 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:21:11 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:21:11 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:21:11 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _c88d1d0a_p_callbackStruct within callback
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:21:11 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=1918
11/12/2004 02:21:11 PM 1457028016 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:21:11 PM 1457028016 VenueClient __init__.py:988 DEBUG remove user: Kristof Ostir
11/12/2004 02:21:11 PM 1457028016 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1573
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG finally read enough data, wait=1573 buflen=1573
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:23:28 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:23:28 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Louisiana State University Baton Rouge (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:23:28 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Louisiana State University Baton Rouge
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Freeing callback _c88d1d0a_p_callbackStruct within callback
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Have new callback handle _c88d1d0a_p_callbackStruct
11/12/2004 02:23:28 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(0, None) n=1573
11/12/2004 02:23:28 PM 1457028016 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:23:28 PM 1457028016 VenueClient __init__.py:988 DEBUG add user: Louisiana State University Baton Rouge
11/12/2004 02:23:42 PM 30493616 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f08c1a0a_p_globus_io_handle_t result=(76, 'an end-of-file was reached') n=0
11/12/2004 02:23:42 PM 30493616 EventClient __init__.py:988 DEBUG readCallback gets failure in result: 76 an end-of-file was reached
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1654
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1654 buflen=1654
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:23:42 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:23:42 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:23:42 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Roger Sersted
11/12/2004 02:23:42 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:23:42 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1572
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1572 buflen=1572
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:24:21 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:24:21 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:24:21 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Louisiana State University Baton Rouge
11/12/2004 02:24:21 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:24:21 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:24:21 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:24:21 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:24:21 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:24:21 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1573
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1573 buflen=1573
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:24:39 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:24:39 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:24:39 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Louisiana State University Baton Rouge (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:24:39 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Louisiana State University Baton Rouge
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1572
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1572 buflen=1572
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:25:07 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:25:07 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Louisiana State University Baton Rouge
11/12/2004 02:25:07 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:25:07 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:25:07 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:25:07 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:25:07 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:25:07 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:25:07 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1573
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1573 buflen=1573
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:25:27 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:25:27 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:25:27 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Louisiana State University Baton Rouge (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:25:27 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Louisiana State University Baton Rouge
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1572
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1572 buflen=1572
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:25:37 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:25:37 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Louisiana State University Baton Rouge
11/12/2004 02:25:37 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:25:37 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:25:37 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:25:37 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:25:37 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:25:37 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:25:37 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=2181
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=2181 buflen=2181
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:25:48 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:25:48 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:25:48 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant DIII-D National Fusion Facility Test (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:25:48 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: DIII-D National Fusion Facility Test
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1573
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1573 buflen=1573
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:26:13 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:26:13 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Louisiana State University Baton Rouge (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:26:13 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Louisiana State University Baton Rouge
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:26:13 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:26:23 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:26:23 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:26:23 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:26:23 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=1572
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=1572 buflen=1572
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:26:24 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:26:24 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:26:24 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Louisiana State University Baton Rouge
11/12/2004 02:26:24 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:26:24 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:26:24 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:26:24 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:26:24 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:26:24 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=2063
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=2063 buflen=2063
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:27:30 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:27:30 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:27:30 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Scott Doney (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:27:30 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Scott Doney
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=2180
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=2180 buflen=2180
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:27:42 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:27:42 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: DIII-D National Fusion Facility Test
11/12/2004 02:27:42 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:27:42 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:27:42 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:27:42 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:27:42 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:27:42 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:27:42 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=2062
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=2062 buflen=2062
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:28:05 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event
11/12/2004 02:28:05 PM 1478007728 VenueClient __init__.py:988 DEBUG remove user: Scott Doney
11/12/2004 02:28:05 PM 1478007728 VenueClient __init__.py:988 DEBUG RemoveUserEvent: Got Remove User Event...done
11/12/2004 02:28:05 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participant
11/12/2004 02:28:05 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
11/12/2004 02:28:05 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Remove participants data
11/12/2004 02:28:05 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
11/12/2004 02:28:05 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.RemoveUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 INFO No callback for Exit!
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Exit event!
11/12/2004 02:28:05 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=4
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG Freeing callback _00c11b0a_p_callbackStruct within callback
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG Have new callback handle _00c11b0a_p_callbackStruct
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_702d220a_p_globus_io_handle_t result=(0, None) n=2119
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG finally read enough data, wait=2119 buflen=2119
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0xf68cd22c>>...done
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 INFO No callback for Enter!
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 INFO Got callback for Enter event!
11/12/2004 02:29:38 PM 1498987440 EventClient __init__.py:988 DEBUG handleData returns
11/12/2004 02:29:38 PM 1478007728 VenueClient __init__.py:988 DEBUG AddUserEvent: Got Add User Event
11/12/2004 02:29:38 PM -150546944 VenueClient __init__.py:988 DEBUG ContentListPanel.AddParticipant:: AddParticipant Montana Tech Access Grid PIG (called from ('/usr/lib/python2.3/site-packages/wx/core.py', 9328, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
11/12/2004 02:29:38 PM 1478007728 VenueClient __init__.py:988 DEBUG add user: Montana Tech Access Grid PIG
