hsotname stuff
Ivan R. Judson
judson at mcs.anl.gov
Fri Mar 26 14:33:58 CST 2004
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> Sent: Friday, March 26, 2004 1:38 PM
> To: ag-dev at mcs.anl.gov
> Subject: hsotname stuff
> The hands-off mechanism for local hostname determination is
> now in place, on windows anyway.
> If a GLOBUS_HOSTNAME is set, its value is left in place
> without checking (bug 888).
> This brings up another issue: it appears that throughout,
> SystemConfig.Gethostname is used; that uses socket.getfqdn()
> which does not benefit from the accurate hostname
> determination. We should either use the globus gethostname,
> or we should make systmeconfig use the globus gethostname.
I'd suggest that we leave systemconfig.gethostname doing what it's doing,
but document the heck out of the fact that it's only for verification, that
we should be using globusconfig.gethostname throughout the toolkit instead.
Does that solve the problem? The reason is, I'd like to know when the system
hostname is not the globus hostname, in some cases.
> Another related issue is this:
> s = ThreadingGSISOAPServer(addr, config = self.config)
> that is, the creation of the servers passing in the current
> hostname. I suspect that if the constructor is working
> properly, we will find that such a server would only listen
> on one interface of a multihomed computer.
That is the correct behavior, or there's a modification that we need to make
to make it correct?
--Ivan
