Fwd: Problem about connection from KMITNB
Robert Olson
olson at mcs.anl.gov
Mon Mar 15 14:38:30 CST 2004
where do we have bridge servers available?
--bob
>X-Qmail-Scanner-Mail-From: e01109 at kmitnb.ac.th via smtp.kmitnb.ac.th
>X-Qmail-Scanner: 1.20 (Clear:RC:1(202.44.32.22):. Processed in 0.016651 secs)
>Date: Tue, 16 Mar 2004 04:00:23 +0700 (ICT)
>Subject: Problem about connection from KMITNB
>To: "Robert Olson" <olson at mcs.anl.gov>
>User-Agent: SquirrelMail/1.4.1
>Importance: Normal
>X-Spam-Status: No, hits=3.0 required=5.0
> tests=FROM_ENDS_IN_NUMS,NORMAL_HTTP_TO_IP,NO_REAL_NAME,
> PRIORITY_NO_NAME,USER_AGENT
> version=2.55
>X-Spam-Level: ***
>X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
>good afternoon
>My name is Worrapong from KMITNB in Thailand.
>Now! I have problem about connect to Access Grid at ANL,At Test Room
>Virtual Venue
>if your site running Bridge Server i should see enable unicast.
>Ummm i see it in all day but problem is i can't connect it.
>Typically, when i click unicast it will pop up window show bridge which
>you build for connection on network not support multicast but all day i
>can't receive that pop up for connect to your site.
>I need your help about suggestion and advice me as soon as possible
>because in 18 March 2004 I will present Access Grid Project at KMITNB.
>I am sorry if i disturb you but your ANL Virtual Venue is easy to connect
>because your site is on all day all night.
>Now! I have Access Grid Node at KMITNB if possible i will attempt run it
>all day all night such as ANL Laboratory.
>For address of KMITNB Node is https://202.44.38.218:8000/Venues/default in
>future i will request DNS for IP 202.44.38.218 for Access Grid.
>Thank you for your help.
>Sincere
>Worrapong
>KMITNB
