Mary and the Library
Ivan R. Judson
judson at mcs.anl.gov
Mon Mar 15 10:16:51 CST 2004
I'm not sure I have it or could retrieve it easily.
This might have slipped by, but it looks like there's an import related
corruption of some sort happening in the cert mgmt stuff (at least in
2.1.2b). We might be able to construct a test to make that happen...
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Monday, March 15, 2004 8:54 AM
> To: judson at mcs.anl.gov; ag-dev at mcs.anl.gov
> Subject: Re: Mary and the Library
> can you send along the venue client logfile from that
> machine? (or, better, submit a bug and attach it there).
> --bob
> At 08:39 AM 3/15/2004, Ivan R. Judson wrote:
> >Here's the scoop;
> >After fiddling with various things and trying different
> combinations of
> >file removal, setting permissions, etc, (which didn't change
> anything
> >in the lib for mary), I gave up and removed the certrepo.
> >After we restarted (which did not require a re-import of her new
> >certificate !?); the signing policy files were correctly
> copied to her
> >trustedCertificates directory. It looks like something in the
> >repository got corrupt and caused a permanent failure of the
> signing_policy file writing.
> >Any ideas?
> >--Ivan
