Fwd: Problem about connection from KMITNB
Thomas D. Uram
turam at mcs.anl.gov
Mon Mar 15 14:46:46 CST 2004
They're listed here:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/BridgedVenues
There's a problem accessing them right now; I'll send mail when they're
accessible again.
Tom
Robert Olson wrote:
> where do we have bridge servers available?
> --bob
>> X-Qmail-Scanner-Mail-From: e01109 at kmitnb.ac.th via smtp.kmitnb.ac.th
>> X-Qmail-Scanner: 1.20 (Clear:RC:1(202.44.32.22):. Processed in
>> 0.016651 secs)
>> Date: Tue, 16 Mar 2004 04:00:23 +0700 (ICT)
>> Subject: Problem about connection from KMITNB
>> To: "Robert Olson" <olson at mcs.anl.gov>
>> User-Agent: SquirrelMail/1.4.1
>> Importance: Normal
>> X-Spam-Status: No, hits=3.0 required=5.0
>> tests=FROM_ENDS_IN_NUMS,NORMAL_HTTP_TO_IP,NO_REAL_NAME,
>> PRIORITY_NO_NAME,USER_AGENT
>> version=2.55
>> X-Spam-Level: ***
>> X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
>> good afternoon
>> My name is Worrapong from KMITNB in Thailand.
>> Now! I have problem about connect to Access Grid at ANL,At Test Room
>> Virtual Venue
>> if your site running Bridge Server i should see enable unicast.
>> Ummm i see it in all day but problem is i can't connect it.
>> Typically, when i click unicast it will pop up window show bridge which
>> you build for connection on network not support multicast but all day i
>> can't receive that pop up for connect to your site.
>> I need your help about suggestion and advice me as soon as possible
>> because in 18 March 2004 I will present Access Grid Project at KMITNB.
>> I am sorry if i disturb you but your ANL Virtual Venue is easy to
>> connect
>> because your site is on all day all night.
>> Now! I have Access Grid Node at KMITNB if possible i will attempt run it
>> all day all night such as ANL Laboratory.
>> For address of KMITNB Node is
>> https://202.44.38.218:8000/Venues/default in
>> future i will request DNS for IP 202.44.38.218 for Access Grid.
>> Thank you for your help.
>> Sincere
>> Worrapong
>> KMITNB
