video producer check in
Ivan R. Judson
judson at mcs.anl.gov
Tue Jun 29 13:31:23 CDT 2004
For the Osprey problem, we should have 2 on order to test and figure out
configuration stuff.
I don't think we can help fix that until they come in.
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Eric Olson
> Sent: Tuesday, June 29, 2004 9:46 AM
> To: ag-dev at mcs.anl.gov
> Subject: video producer check in
> Just a heads up, I made a change to VideoProducer.py that
> fixes a problem that port settings from the config file
> getting loaded, but were being overridden by the default
> port. This is why our one camera in the WS wasn't working
> before (i'll go fix it now). Someone else (maybe Tom since
> he has some experience with this) may want to verify this is
> a reasonable fix.
> This fixes one outstanding problem with video producer
> settings, but there may be one or two more:
> * People on ag-tech having problems with windows capture cards in XP.
> * Strange situations, that I haven't seen recently, where the
> /dev/video entries weren't showing up in Node Management,
> and/or we were only given the choice of the x11 video device
> (could have been a problem with the video machine setup such
> as the bttv module not loaded).
> Eric
> ---------- Forwarded message ----------
> Date: Tue, 29 Jun 2004 09:34:06 -0500
> From: Eric Olson <eolson at mcs.anl.gov>
> To: ag-cvs at mcs.anl.gov
> Subject: [CVS AccessGrid] VideoProducerService.py:Don't
> override the port
> setting that was loaded in the default config.
> Commit in AccessGrid/services/node on MAIN
> VideoProducerService.py+6-2 | 1.29 -> 1.30
> Don't override the port setting that was loaded in the
> default config.
> Keep the setting if it's one of the valid portTypes.
> ______________________________________________________________
> __________________
> VideoProducerService.py 1.29 -> 1.30
> diff -u -r1.29 -r1.30
> --- VideoProducerService.py 27 May 2004 16:11:03 -0000 1.29
> +++ VideoProducerService.py 29 Jun 2004 14:34:06 -0000 1.30
> @@ -5,7 +5,7 @@
> # Author: Thomas D. Uram
> # Created: 2003/06/02
> -# RCS-ID: $Id: VideoProducerService.py,v 1.29
> 2004/05/27 16:11:03 turam Exp $
> +# RCS-ID: $Id: VideoProducerService.py,v 1.30
> 2004/06/29 14:34:06 eolson Exp $
> # Copyright: (c) 2002
> # Licence: See COPYING.TXT
> @@ -244,7 +244,11 @@
> # Create the port parameter as an option set
> parameter, now
> # that we have multiple possible values for "port"
> - self.port = OptionSetParameter( "port",
> self.resource.portTypes[0],
> + if ( isinstance(self.port, TextParameter) or
> isinstance(self.port, ValueParameter) ) and self.port.value
> != "" and self.port.value in self.resource.portTypes:
> + self.port = OptionSetParameter( "port",
> self.port.value,
> self.resource.portTypes )
> + else:
> + self.resource.portTypes[0],
> # Replace or append the "port" element
> CVSspam 0.2.8
