video producer check in
Eric Olson
eolson at mcs.anl.gov
Tue Jun 29 09:46:16 CDT 2004
Just a heads up, I made a change to VideoProducer.py that fixes a
problem that port settings from the config file getting loaded,
but were being overridden by the default port. This is why our one camera
in the WS wasn't working before (i'll go fix it now). Someone else (maybe
Tom since he has some experience with this) may want to verify this is a
reasonable fix.
This fixes one outstanding problem with video producer settings, but there
may be one or two more:
* People on ag-tech having problems with windows capture cards in XP.
* Strange situations, that I haven't seen recently, where the /dev/video
entries weren't showing up in Node Management, and/or we were only given
the choice of the x11 video device (could have been a problem with the
video machine setup such as the bttv module not loaded).
Eric
---------- Forwarded message ----------
Date: Tue, 29 Jun 2004 09:34:06 -0500
To: ag-cvs at mcs.anl.gov
Subject: [CVS AccessGrid] VideoProducerService.py:Don't override the port
setting that was loaded in the default config.
Commit in AccessGrid/services/node on MAIN
VideoProducerService.py+6-2 | 1.29 -> 1.30
Don't override the port setting that was loaded in the default config.
Keep the setting if it's one of the valid portTypes.
________________________________________________________________________________
VideoProducerService.py 1.29 -> 1.30
diff -u -r1.29 -r1.30
--- VideoProducerService.py 27 May 2004 16:11:03 -0000 1.29
+++ VideoProducerService.py 29 Jun 2004 14:34:06 -0000 1.30
@@ -5,7 +5,7 @@
# Author: Thomas D. Uram
# Created: 2003/06/02
-# RCS-ID: $Id: VideoProducerService.py,v 1.29 2004/05/27 16:11:03 turam Exp $
+# RCS-ID: $Id: VideoProducerService.py,v 1.30 2004/06/29 14:34:06 eolson Exp $
# Copyright: (c) 2002
# Licence: See COPYING.TXT
@@ -244,7 +244,11 @@
# Create the port parameter as an option set parameter, now
# that we have multiple possible values for "port"
- self.port = OptionSetParameter( "port", self.resource.portTypes[0],
+ if ( isinstance(self.port, TextParameter) or isinstance(self.port, ValueParameter) ) and self.port.value != "" and self.port.value in self.resource.portTypes:
+ self.port = OptionSetParameter( "port", self.port.value,
+ self.resource.portTypes )
+ else:
+ self.port = OptionSetParameter( "port", self.resource.portTypes[0],
# Replace or append the "port" element
CVSspam 0.2.8
