video producer update
Eric Olson
eolson at mcs.anl.gov
Tue Jun 29 14:04:11 CDT 2004
I haven't had time to verify whether the video producer checkin fixes the
port setting issues on the full workshop node (I probably need to bump the
video producer version). It did fix the loading of a config from my
windows laptop connected to ws-video.
In the meantime, the WS camera that wasn't working is working now because
there was an rca/composite cable from the camera available to plug into
the video board.
Eric
On Tue, 29 Jun 2004, Eric Olson wrote:
> Just a heads up, I made a change to VideoProducer.py that fixes a
> problem that port settings from the config file getting loaded,
> but were being overridden by the default port. This is why our one camera
> in the WS wasn't working before (i'll go fix it now). Someone else (maybe
> Tom since he has some experience with this) may want to verify this is a
> reasonable fix.
> This fixes one outstanding problem with video producer settings, but there
> may be one or two more:
> * People on ag-tech having problems with windows capture cards in XP.
> * Strange situations, that I haven't seen recently, where the /dev/video
> entries weren't showing up in Node Management, and/or we were only given
> the choice of the x11 video device (could have been a problem with the
> video machine setup such as the bttv module not loaded).
> Eric
> ---------- Forwarded message ----------
> Date: Tue, 29 Jun 2004 09:34:06 -0500
> From: Eric Olson <eolson at mcs.anl.gov>
> To: ag-cvs at mcs.anl.gov
> Subject: [CVS AccessGrid] VideoProducerService.py:Don't override the port
> setting that was loaded in the default config.
> Commit in AccessGrid/services/node on MAIN
> VideoProducerService.py+6-2 | 1.29 -> 1.30
> Don't override the port setting that was loaded in the default config.
> Keep the setting if it's one of the valid portTypes.
> ________________________________________________________________________________
> VideoProducerService.py 1.29 -> 1.30
> diff -u -r1.29 -r1.30
> --- VideoProducerService.py 27 May 2004 16:11:03 -0000 1.29
> +++ VideoProducerService.py 29 Jun 2004 14:34:06 -0000 1.30
> @@ -5,7 +5,7 @@
> # Author: Thomas D. Uram
> # Created: 2003/06/02
> -# RCS-ID: $Id: VideoProducerService.py,v 1.29 2004/05/27 16:11:03 turam Exp $
> +# RCS-ID: $Id: VideoProducerService.py,v 1.30 2004/06/29 14:34:06 eolson Exp $
> # Copyright: (c) 2002
> # Licence: See COPYING.TXT
> @@ -244,7 +244,11 @@
> # Create the port parameter as an option set parameter, now
> # that we have multiple possible values for "port"
> - self.port = OptionSetParameter( "port", self.resource.portTypes[0],
> + if ( isinstance(self.port, TextParameter) or isinstance(self.port, ValueParameter) ) and self.port.value != "" and self.port.value in self.resource.portTypes:
> + self.port = OptionSetParameter( "port", self.port.value,
> + self.resource.portTypes )
> + else:
> + self.port = OptionSetParameter( "port", self.resource.portTypes[0],
> # Replace or append the "port" element
> CVSspam 0.2.8
