globus worries
Robert Olson
olson at mcs.anl.gov
Fri Jan 30 14:58:04 CST 2004
I agree; just don't know the current status of winglobus for 2.4.3+..
--bob
At 02:51 PM 1/30/2004, Ivan R. Judson wrote:
>I don't have this working to test, and I'm mostly sure nobody else does
>either. This would seem to be high enough priority for you to push on
>getting it working in your environment to test.
>This ia big problem we need to have addressed ASAP.
>--Ivan
> > -----Original Message-----
> > From: owner-ag-dev at mcs.anl.gov
> > [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> > Sent: Thursday, January 29, 2004 6:07 PM
> > To: ag-dev at mcs.anl.gov
> > Subject: Re: globus worries
> > Drat, here are the files.
> > --bob
> > At 06:01 PM 1/29/2004, Robert Olson wrote:
> > >I determined today that we've not actually been getting
> > encryption on
> > >our globus data connections, only the default of integrity checking,
> > >despite the easy misreading of the docs that would imply
> > that GSS_WRAP
> > >means encrypted connections.
> > >The larger problem is that it appears that under the old winglobus
> > >turning on encryption causes authentication errors.
> > >Can someone with a pyGlobus built against the latest
> > winglobus please
> > >try the attached client and server? just run testserv.py, then
> > >testcli.py on the same machine.
> > >thanks,
> > >--bob
