globus worries
Ivan R. Judson
judson at mcs.anl.gov
Fri Jan 30 15:15:48 CST 2004
I'm trying to compile pyglobus against bob's latest code (from his
homepage). Matt and I are poking at things to try and make it work.
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Friday, January 30, 2004 2:58 PM
> To: judson at mcs.anl.gov; ag-dev at mcs.anl.gov
> Subject: RE: globus worries
> I agree; just don't know the current status of winglobus for 2.4.3+..
> --bob
> At 02:51 PM 1/30/2004, Ivan R. Judson wrote:
> >I don't have this working to test, and I'm mostly sure
> nobody else does
> >either. This would seem to be high enough priority for you
> to push on
> >getting it working in your environment to test.
> >This ia big problem we need to have addressed ASAP.
> >--Ivan
> > > From: owner-ag-dev at mcs.anl.gov
> > > [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> > > Sent: Thursday, January 29, 2004 6:07 PM
> > > To: ag-dev at mcs.anl.gov
> > > Subject: Re: globus worries
> > > Drat, here are the files.
> > > --bob
> > > At 06:01 PM 1/29/2004, Robert Olson wrote:
> > > >I determined today that we've not actually been getting
> > > encryption on
> > > >our globus data connections, only the default of integrity
> > > >checking, despite the easy misreading of the docs that
> would imply
> > > that GSS_WRAP
> > > >means encrypted connections.
> > > >The larger problem is that it appears that under the old
> winglobus
> > > >turning on encryption causes authentication errors.
> > > >Can someone with a pyGlobus built against the latest
> > > winglobus please
> > > >try the attached client and server? just run testserv.py, then
> > > >testcli.py on the same machine.
> > > >thanks,
> > > >--bob
