globus worries
Ivan R. Judson
judson at mcs.anl.gov
Fri Jan 30 14:51:39 CST 2004
I don't have this working to test, and I'm mostly sure nobody else does
either. This would seem to be high enough priority for you to push on
getting it working in your environment to test.
This ia big problem we need to have addressed ASAP.
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> Sent: Thursday, January 29, 2004 6:07 PM
> To: ag-dev at mcs.anl.gov
> Subject: Re: globus worries
> Drat, here are the files.
> --bob
> At 06:01 PM 1/29/2004, Robert Olson wrote:
> >I determined today that we've not actually been getting
> encryption on
> >our globus data connections, only the default of integrity checking,
> >despite the easy misreading of the docs that would imply
> that GSS_WRAP
> >means encrypted connections.
> >The larger problem is that it appears that under the old winglobus
> >turning on encryption causes authentication errors.
> >Can someone with a pyGlobus built against the latest
> winglobus please
> >try the attached client and server? just run testserv.py, then
> >testcli.py on the same machine.
> >thanks,
> >--bob
